ball joint removal
Discussion in 'The Garage' started by chevy wrangler, Nov 17, 2006.
  1. chevy wrangler
    chevy wrangler 1/2 ton status
    Jun 15, 2006
    3,035
    el paso, texas
    how hard is it to change a ball joint on a 1/2 ton 44?? i need to swap out the bottom one with a new one and while im at it ima change the u-joints as well, what kind of u-joints am i gonna need for it?? instructions would be helpful and thanxs in advanced:D
  2. chevy wrangler
    Jun 15, 2006
    3,035
    el paso, texas
    anybody??ttt i hope to do this saturday or on sunday
  3. 4X4HIGH
    Dec 14, 2001
    22,060
    69
    Pleasanton, CA.
    If you don't have a press and a bunch of different fixtures then i would suggest you take it to a shop to have the ball joints done. Also don't do just the lower change them both.
  4. savagek5diesel
    savagek5diesel 1/2 ton status
    Nov 20, 2003
    310
    Redding California
    x2 with changing both, and on each side. i was able to change mine with a bfh and a high lift jack, but that sucked. go to harbor frieght and get their ball joint remover/install kit for a few bucks to save yourself a few curse words.
  5. broc944
    broc944 1/2 ton status
    Sep 23, 2005
    1,660
    Northern Minnesota
    If you do not have a ball joint press you are really going to regret it, it is still a pain to do with the correct tools.
    As everyone else said change everything, waste of time and money otherwise.
  6. chevy wrangler
    Jun 15, 2006
    3,035
    el paso, texas
    well its off but cant put the new one in and i also fixed my busted up axle shaft
  7. 84 K5 4x4
    84 K5 4x4 1/2 ton status
    Nov 14, 2006
    163
    Jasper Ga
    I have always used a rose bud and a BFH works great just dont get it to hot
  8. sandy78
    sandy78 Registered Member
    Nov 28, 2002
    84
    Utah
    I "rented" a press from Autozone. Not too bad with the tool if you have an air gun to drive it. Basically it is a big C-Clamp with some spacers to fit over the ball joint. One way goes in, one goes out. Buy the funky adjusting socket for the taper nut thingy on the top axle ear. I think it was $12 or so at Pep Boys. Then you torque it to preload the assembly before putting final torque on the joints themselves. Good luck!
  9. chevy wrangler
    Jun 15, 2006
    3,035
    el paso, texas
    how does this "press" work???
  10. 86dieselburb
    86dieselburb 1/2 ton status
    Oct 20, 2004
    219
    Crestline, CA
    http://search.harborfreight.com/cpisearch/web/search.do?keyword=Ball+joint&Submit=Go
    I just did mine couple of weeks ago. Used the Harbor Freight one time use (as is most of their tools) ball joint press. I also got their master ball joint adpater set. Didn't want to be without the right adapter. The press is a big aluminum C-clamp. I used a big cheater bar. I highly recommend to use a big impact gun. The cheater bar put a lot of stress on the clamp and ovaled the threaded part of the clamp so by the time I got to the last axle u-joint it barely worked.
    Not a bad job, just takes some torguing to get them suckers out and back in again. Good luck
  11. MattK
    MattK 1/2 ton status
    Jan 12, 2005
    1,713
    Dallas, TX
    i used that for doin the 10b balljoints last year. i use the impact every time i use that tool. it's not bad, but keep it lubed.
  12. goldwing2000
    goldwing2000 Guest
    This a good page to view.
    http://www.madxj.com/MADXJ/technical/technicalfiles/ARadjustableBallJoints/adjustableballjoints.htm
    He has numbers for both the parts and the tools.
    The title of the page is Adjustable Ball Joints but the R&R process is the same for regular ones.
    I have a Matco ball joint press and I've used it over and over and over. I never use an impact gun on it (bad for the threads) and it's never even hesitated to knock out any ball joint I've ever tried.
    I use the trusty hammer-and-socket method for u-joints. Been doing it for 20 years and has always worked like a charm.
  13. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    never have and can't imagine using a balljoint press by hand... air tools are ALWAYS your friend.
  14. chevy wrangler
    Jun 15, 2006
    3,035
    el paso, texas
    i used one by hand and a bf braker bar!!LOL i love rental tools, well thanks everybody for your help. i finished it and i also installed a new axleshaft and u-joint. thanks again :)
  15. ssped
    ssped 1/2 ton status GMOTM Winner
    Jan 5, 2006
    1,529
    Mission Viejo
    Did mine today. The knuckle was tight turning when I finished. was yours tight as well?
  16. chevy wrangler
    Jun 15, 2006
    3,035
    el paso, texas
    not alot but i could turn it by hand
  17. sled_dog
    Sep 3, 2002
    16,870
    Austin, TX
    they usually are. Bearings and joints that spin very freely are usually not so good. It means they aren't tight, or greased well(sealed bearings anyway). So resistance when you turn the knuckle by hand after installing new balljoints is perfectly fine. Now if you simply CAN'T turn it, then that isn't quite right.
  18. ssped
    Jan 5, 2006
    1,529
    Mission Viejo
    It turns. it is just stiff. I am guessing it is fine. thanks
