ball joint replacement problems
Discussion in 'The Garage' started by big dan, Jun 7, 2006.
  1. big dan
    big dan 1/2 ton status Premium Member
    Aug 1, 2005
    2,656
    29
    Arkansas
    recently I discovered that I needed to replace 2 of my ball joints. no big deal I got all 4 so I could replace them while I had it apart. the problem is that I broke 3 ball joint seperators trying to remove one side. is there anything I can do to loosen them up?
    thanks
  2. 70jimmy
    70jimmy 3/4 ton status Premium Member GMOTM Winner
    Mar 3, 2000
    5,956
    249
    Released from Pueblo, told I belong in Southpark
    use a small sledge or ball peen and smack on the area around the ball joint. Not on the knuckle but the part that is attached to the axle. Took me about 5 wacks and it comes out. alternate between top and bottom. I didn't even touch a separator. Good luck!!
    Might throw the nuts on a few threads in case your aim is a little off!!
  3. K5Greek
    K5Greek 1/2 ton status
    Nov 25, 2005
    2,054
    Vineland, NJ
    what he said, this is also what my auto tech teachers tells us. i think most areas have a little piece that sticks out not much but you should notice a difference and that is where you hit it..2-3 hits and you should be loose.
  4. Zeus33rd
    Mar 14, 2002
    7,324
    9
    Grass Valley, CA
    You're not gonna use the old ones right? :crazy: Just screw the nut back on a bit and wail on the top ball joint with a big ass sledge.. Doesn't matter if the nut or ball joint gets fuucked up, you alread have new stuff.
  5. big dan
    Aug 1, 2005
    2,656
    29
    Arkansas
    course Im not gonna use the old ones. they're pretty bad. when its sitting still the top of the tire points in and the bottom points out so I got all 4 new ones. Ill try the advice mentioned and see if that helps. One more question, would heating them help any?
    thanks
  6. MoonMan
    MoonMan Registered Member
    Mar 12, 2003
    56
    Tyrone, Pa
    Try loosening the sleeve on the upper ball joint.
  7. Citizen Rider
    Citizen Rider 1/2 ton status
    May 5, 2005
    1,415
    Plano, Texas
    PB Blaster is your friend!!!
    Heat can help, but you need an oxy-acetelyne torch and it takes alot to get it hot enough, then hammering them out. I did them on jeeps a couple times. Best thing is to just wale on them with a big sledge.
