Ball joint replacement
Discussion in 'The Garage' started by outlawtorn, Nov 23, 2004.
  1. outlawtorn
    outlawtorn 1/2 ton status
    Jul 21, 2004
    365
    Box Elder, SD
    Well my upper and lower ball joints have about an inch of play in them so i think its time to replace them lol. Ive never done this before and was wondering if a guy could do it in his driveway in a afternoon or what? Do i need any special tools etc.? If someone has a good writeup on this point me towards it. Any help would be apprieciated /forums/images/graemlins/thumb.gif
  2. mechted
    mechted 1 ton status Premium Member
    Oct 19, 2003
    767
    Granbury, TX
    i just did this... learning along the way, it took me most of a weekend (ran into u-joint problems so it actually took longer.. but whatever) I would say if you know how to tear down the knuckles already, and you dont run into other problems, it should only take you a day
    it does require a ball joint press (rented at autozone)
    and the hub socket ($19 to buy, i think you can rent them too)
    also there is a special adjusting sleve for the upper ball joint.. it requires a spanner wrench and has to be torqued to about 100 ft lbs
    and i found that a ball joint seperating tool helped out.
    other than than, just the basic tools... except maybe a 1 5/16" socket for the upper ball joint nut
  3. scubahard
    scubahard Registered Member
    Nov 3, 2004
    47
    California
    It took me an entire weekend as well. Removing the spindle was a little tricky. The two locking nuts with the small pin on the spindle were tough. I didn't expect that. Give yourself a couple of days for the first time around. Check your U-joints, bearings, and brakes. I just replace everything since I had it all apart. Each caliper was $12. Heck, I only wanted to do it all once.
  4. ntaj*ep
    ntaj*ep 1/2 ton status
    Feb 4, 2002
    3,248
    Evergreen state
    Your going to need a balljoint press, other than that your golden.
  5. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Removing the spindle is a piece of cake. Either put a 4x4 block on it and beat it with a hammer, or go to autozone and get a spindle puller (free to rent).
  6. divorced
    divorced 3/4 ton status
    Jul 20, 2004
    5,115
    50 ft. lbs.
  7. mechted
    Oct 19, 2003
    767
    Granbury, TX
    50 ft. lbs.
    whoops.. got the two torques switched (serves me right for going off memory!) thanks for catching that
  8. divorced
    Jul 20, 2004
    5,115
    It happens to the best of us /forums/images/graemlins/smile.gif. I just posted the link because it has all of the specs in it.
