ball joint replacement
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by beefjerky, Aug 22, 2001.
  1. beefjerky
    beefjerky Registered Member
    Feb 14, 2001
    64
    my 86 k5 blazer needs new ball joints. is this something i can attempt in my garage? if so, any helpful hints and suggestions would be great. thanks
  2. ftn96
    ftn96 1/2 ton status
    Sep 26, 2000
    3,238
    Nashville Tn
    I have a write up I can E-mail you tomorrow. You just need to PM me tomorrow if you can and remind me.
    What is and what should never be....
    <a target="_blank" href=http://www.nashvillek5.freeservers.com>www.nashvillek5.freeservers.com</a>
  3. MudTruk
    MudTruk Registered Member
    Jul 21, 2001
    32
    Norman, Oklahoma
    Replacing ball joints can be very tricky. However, it does not take a lot of technical skill. I replaced them on my old blazer. The hardest part for me was to gain access to a press to press the new ones in. A special socket will be needed to remove the upper ball joint. I got mine from a Snap-on dealer. Just stopped him one day and asked for it. Cost was about $40. I had a hard time finding any place else that even knew what one was. Good luck.
    Pete
    Gotta go, before ya show!
  4. Pugsley
    Pugsley 1/2 ton status
    Jan 16, 2001
    3,556
    Tucson, Arizona
    Napa also stocks the ball joint socket - same quality as Matco for far less money.
    Dos mas Tecates!!!
    <a target="_blank" href=http://pugsley.alloffroad.com>pugsley.alloffroad.com</a>
  5. Triaged
    Triaged 1/2 ton status
    Feb 21, 2001
    3,808
    CA (LA/OC area)
    As the others have said you need the special socket (I coulden't find one so I made one) and to press out/in the balljoints. You also need a 1-5/16" socket (if the castle nut size is the same as my D44).
    '71 Blazer CST w/ a 400sbc, 4" lift, 36" Supper Swampers, and alot of rust
  6. ftn96
    Sep 26, 2000
    3,238
    Nashville Tn
    Yep, the 10 bolt requires the 1 5/16 socket as well.
