Ball Joint rubber grease inserts
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by sickquad, Aug 27, 2003.
  1. sickquad
    sickquad 1/2 ton status
    Jul 23, 2003
    785
    Ma
    So, I installed my new MOOG ball joints thanks to all of the info available here on the board. Went really well. Except one thing. The ball joints did not come with the rubber plugs to put in the grease fitting hole when you remove the grease fitting. Anybody know where I could get some of these? Or does anyone have any they could send me?
    Chris
  2. berg76
    berg76 1/2 ton status
    Nov 4, 2002
    238
    St. Louis, Missouri
    Autozone had a little package with replacment fittings. Also came with a plug you need.
  3. sickquad
    Jul 23, 2003
    785
    Ma
    I went everywhere today looking for those rubber inserts with no luck, including Autozone, anyone else have any ideas?
  4. Can Can
    15,552
    136
    Cochrane, Alberta, Canada
    Why do you have to remove the fittings on your ball joints? Mine are permanent and I've never had any problems. Am I missing something? /forums/images/graemlins/confused.gif
  5. berg76
    Nov 4, 2002
    238
    St. Louis, Missouri
    If you leave the filler fitting on the upper balljoint it will break off when you insert the axle shaft. Plus there isnt enough room to fit a grease gun on the upper one. The lower balljoint was fine obvioulsy. Thats my experiance on my 10bolt. I dont know about other axles.
  6. Chris_T
    Chris_T 1/2 ton status
    Mar 17, 2001
    718
    Saskatoon, SK
    I don't know about rubber plugs, but mine came with low profile brass threaded inserts last time I changed one
  7. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    I put red silicone in mine years ago and forgot about it. /forums/images/graemlins/grin.gif
  8. Can Can
    15,552
    136
    Hmmmmmmmmmmm, that's very strange. I've swapped out both sides on my 84 10 bolt and have had no issues with my zerks. The only thing I had to do was use a grease needle to get to the upper ball joint fittings. I couldn't reach the fitting without the needle.
    Heck, everyone should have a needle anyhow. It's the only way you're able to reach greasable u-joints on the rear shaft as well.
  9. 4X4HIGH
    Dec 14, 2001
    22,063
    70
    Pleasanton, CA.
    The latest MOOG ball joints I have seen changed the placement of the grease fitting from its common bottom position which will interfere with the axle U-joint to the side of the ball joint at an angle so you can leave the grease fitting in and be able to grease it easily
