Ball Joint socket?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by TX Mudder, Apr 30, 2002.
  1. TX Mudder
    TX Mudder 1/2 ton status
    Jul 10, 2000
    2,514
    Houston
    I'm ready to install balljoints.
    I have a copy of the instructions FTN96 gave me.
    Now, where do I buy the ball joint socket? There is an adjusting sleeve on the balljoint that apparently takes a special socket.
    DOes anyone have an online link to one? The part store guys are clueless and the tool mage they have list ball jount seperators, but no spanner wrench or ball joint socket or anything like that.
    This is the only thing stopping me and I have a few days off, so I want to get it done.
    -- Mike
  2. TX Mudder
    Jul 10, 2000
    2,514
    Houston
    In the instructions, it calls it a 'sleeve socket tool'
    IT even gives a part no. C-4169 for 'Miller Special Tool Company' in Garden City, MI 48135.
    I can't find anything on this online.
    Here's a pic of the sleeve.
    <a target="_blank" href=http://users3.ev1.net/~mattell/frame/sleeve.jpg>http://users3.ev1.net/~mattell/frame/sleeve.jpg</a>
    -- Mike
  3. rampage
    rampage 1/2 ton status
    Mar 20, 2001
    2,260
    72
    Humboldt/Pacifica, CA
    I just did mine this weekend. I searched all the local tool/parts stores with the adjusting sleeve in my hand and they all looked at me sort of strange. What I ended up doing was getting a 3/4 inch deep socket that is used for spark plugs and cut it to give it the 4 prongs on the end. I wonder if this socket will still be covered by the lifetime warrenty /forums/images/icons/laugh.gif
  4. POWERMAD
    POWERMAD 1/2 ton status
    Mar 4, 2001
    3,466
    Oregon
    I got mine from Snap-on for a whopping $15.
    OTC tools also makes them.
    Every tool truck that stops in my shop has them on board and I have seen them in Napa.
    The part # for the Snap On one is S9613
  5. TX Mudder
    Jul 10, 2000
    2,514
    Houston
    Sounds like an idea.
    Those sockets are pretty tough - what did you cut it with?
    I have access to a die grinder, sawzall, etc.
    -- Mike
  6. rampage
    Mar 20, 2001
    2,260
    72
    I used a die grinder, being very careful of course. A little filing didn't hurt either.
    I went to Napa, where I got my ball joints at, and they didn't have or know of any such tool. I was talking to the owner too who has been there for 15 yrs. Do you have the Napa part # so I can get it for future reference?
  7. POWERMAD
    Mar 4, 2001
    3,466
    Oregon
    <a target="_blank" href=http://toolsource.com:888/ost/product.asp?sourceid=http%3A%2F%2Ftoolsource%2Ecom%3A888%2Fost%2Fresults%2Easp%253fqu%3Dsteering%2Bwheel%2Bor%2Btie%2Brod%2Bor%2Bball%2Bjoint%2526dept%255fid%3D500%2526mscssid%3Dxkrlh7ht3hs92p6a00j74979am6pc4ad%2526brand%5Fid%3D%2526sourceid%3D&amp;dept%5Fid=500&amp;pf%5Fid=61853&amp;mscssid=XKRLH7HT3HS92P6A00J74979AM6PC4AD>ball joint socket</a>
    That is the OTC one
  8. bigmack
    bigmack 1/2 ton status
    Jan 3, 2002
    478
    Tennessee
    I was reading the description from the link that POWERMAD left, it says it's for Dana frontends. I am going to replace my ball joints soon, but I have a 10-bolt front end, would I need one of these sockets or is a 10-bolt different ?
  9. Rebel88
    Rebel88 1/2 ton status
    Sep 7, 2000
    1,855
    Richmond, VA
    i have the one for the 10 bolt, i doubt it would be the same one for the 60. i got mine from the snap on man...i also got my hub locknut tool for a 14b full floater from the snap on dude
    i can post some pics if you want
    Later
  10. JIM88K5
    JIM88K5 1/2 ton status
    Apr 27, 2001
    1,384
    Vancouver, Wa
    Got mine from snap-off... Might also try craftsman. Car Quest may also carry one.
    Jim
  11. 87GMC
    87GMC 1/2 ton status
    Nov 5, 2001
    653
    Olathe, KS 66061
    Got mine from Napa.
    Says "ingalls" and has the number "2979" printed on it.
  12. mike reeh
    mike reeh 1/2 ton status
    Jul 23, 2001
    752
    San Diego, CA
    The day I did my ball joints (about 2 months ago) nobody had the tool. napa had to order it, and I wasnt waiting around shops for a tool truck to come by, if you know what I mean.
    so I went to kragen and for 10 bucks bought a deep metric socket something like 17MM or so, and took it home, clamped it in a vice and set the adjusting sleeve on it, and marked out where I wanted to remove material.. then I used an air die grinder to remove said material, and I also had to use a round steel bit like you'd use for porting a head, to remove material inside the socket - so it would fit over the ball joint stud... took me a good 10-15 mins of playing with the die grinder but it ended up working perfect.. so I busted out the engraver and wrote "mikes ball joint socket SAVE!!" on it.. I sure would have rather payed $5 more for the napa or snap on one, but I didnt have that option...
    mike
  13. POWERMAD
    Mar 4, 2001
    3,466
    Oregon
    Yes the socket will work for a corporate 10 bolt, everything from the knuckles out is the same as a D44.
  14. bigmack
    Jan 3, 2002
    478
    Tennessee
    Thanks everbody for the responses, I was trying to get my ducks in a row before I started tearing everything apart.
  15. bigmack
    Jan 3, 2002
    478
    Tennessee
    Thanks for the offer but I will just go to the link and print the picture. I got my 14ff socket from a local part store, I think it was about 20 dollars. I used to get weak kneed when I would walk into on of those snap-on trucks, I think I had and still have a major case of tim the tool man syndrome.
