Ball Joint Spanner -source?
Discussion in 'The Garage' started by mechted, Dec 29, 2004.
  1. mechted
    mechted 1 ton status Premium Member
    Oct 19, 2003
    765
    Granbury, TX
    Need to find the spanner socket for the adjusting sleeves for a D44... so far the only places i have found any are Snapon and Mac... or Ebay...
    anyone know of a place i could pick one up locally?
    I checked all the usual suspects: Kragen, Napa, Autozone and came up dry
  2. tunedportk5
    tunedportk5 1/2 ton status
    Jul 13, 2004
    371
    Union City, CA
    I got one from the local tool supply place or I'm sure your better parts store like napa, car quest, sp automotive would have one or order and have the next day for you
  3. POWERMAD
    POWERMAD 1/2 ton status
    Mar 4, 2001
    3,466
    Oregon
    Got mine from snap on $15.
    Find a shop in your area and find out when the dude stops in.
    Most likely he will have it on the truck or can have it the following week.
  4. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    I got mine from Snap On.
    Harley
  5. divorced
    divorced 3/4 ton status
    Jul 20, 2004
    5,115
    I bought mine for $20 at Napa. They won't have one on the shelf, they will have to get off their a$$es and get out the big book that is about 400 pages thick, it will be in there. I don't think that there is a hand tool or service tool that Napa can't order, they just have to be able to find it in their book.
  6. MTBLAZER89
    MTBLAZER89 3/4 ton status Premium Member GMOTM Winner
    Aug 14, 2001
    7,272
    236
    Oak Harbor, WA
    I have bought two from local auto stores...both of them broke:mad: I am sure snap on or Mac are much better quality, but I just finally made my own from a 19-20mm deep socket. Took and angle grinder with a thin wheel and about 15 minutes. Take the nut and a sharpie and mark the areas on the socket that need to be cut out.....or buy a good one..I'm just cheap:D
  7. loafer
    loafer 1/2 ton status
    Aug 19, 2003
    634
    Lyman, Maine
    You can make one...
    I made mine out or $4, 3/4" 1/2" drive socket. I used one of the new adjusting sleeves to mark where the cuts had to be made and used an angle grinder to grind out the end of the socket to form the four prongs. It's worked great so far and was easy to make.
  8. sickquad
    sickquad 1/2 ton status
    Jul 23, 2003
    785
    Ma
    I made my own.
  9. Triaged
    Triaged 1/2 ton status
    Feb 21, 2001
    3,808
    CA (LA/OC area)
    Made my own out of an impact socket.
  10. Smitty
    Smitty 1/2 ton status
    Sep 1, 2000
    999
    Crestview, FL
    Getting it off the truck is the way to go. I had to order mine online from Snap-On and the shipping cost was as much as the tool.:( Now that I've used it, I would recommend just taking a deep socket and cutting it down to fit the sleeve. Like has been said before, you can use the sleeve in the new ball joint to see how to cut the socket.
