Ball Joint Thread Size?
Discussion in 'The Garage' started by goldwing2000, Oct 11, 2006.
  1. goldwing2000
    goldwing2000 Guest
    Tried a search but couldn't find anything...
    Does anybody know what the thread pitch and size is for the upper ball joint adjusting sleeve on a 10-bolt? I know it's bigger than 1"-8, but I don't know how much bigger and I don't have an adjuster sleeve on hand to measure.
    Thanks.
  2. goldwing2000
    goldwing2000 Guest
  3. sweetk30
    Nov 1, 2004
    25,526
    526
    horseheads , ny 14845
    if i recall its pipe thread for the taper to preload the ball joint. but i cant recall 100% as i play with 60s now.
  4. diesel4me
    Jul 24, 2003
    17,537
    922
    Massachussetts
    I'll measure one..
    I think I have an adjusting sleeve in my shop in a junk drawer--I'll try to find it and measure it..I think it does have pipe thread--looks like 3/4" pipe--I'll post back tomorrow if I can find it..:crazy:
  5. sweetk30
    Nov 1, 2004
    25,526
    526
    if not i have some and can check also it sits with my snap on tool left over from the 44 days.
  6. goldwing2000
    goldwing2000 Guest
    It's definitely not tapered pipe thread. You can thread it all the way through the axle, if you want to. That's how I got mine out, since the top threads were buggered up.
    It preloads the ball joint on the tapered shaft on the ball joint itself.
    If one of you could give me an O.D. and TPI on the sleeve, that would be great. :waytogo:
  7. goldwing2000
    goldwing2000 Guest
    bump? anybody? :confused:
  8. dremu
    Feb 27, 2000
    15,952
    443
    East of San Francisco
    All you had to do was ask. :D
    Well, that and I happened to find a spare adjuster while looking for some washers =))
    Anyway, looks like ~1.118" OD, ~.800" ID, and if there are six threads in 1/2", I presume that to be 12TPI.
    I can mail you the spare if you want it, take pix, whatever.
    -- A
  9. goldwing2000
    goldwing2000 Guest
    Awesome. I would assume 1.118" would be 1 1/8" thread diameter and 1 1/8-12 does appear to be a standard size available from McMaster!
    1 1/8"-122 9/16"5 7/16" 26035A537 39.51
    Thanks, dremu!
    Now... to see what I can do to fool my work into buying a $40 tap. :thinking:
  10. diesel4me
    Jul 24, 2003
    17,537
    922
    Massachussetts
    too late!..
    Sorry--I got side tracked over the weekend!:doah: --I did find the sleeve in a junk drawer in my shop last night..but I guess your all set with the dimensions,so I'll toss it back in the drawer I guess...:crazy:
  11. goldwing2000
    goldwing2000 Guest
    If you could verify the diameter and measure the pitch for me with an actual pitch gauge, that would be awesome. :waytogo:
  12. dremu
    Feb 27, 2000
    15,952
    443
    I take it a pitch gauge isn't something used in roofing or baseball? :haha:
    -- A
  13. goldwing2000
    goldwing2000 Guest
    I suppose they would use one in roofing but I don't think it would be of much use in this case. :p:
  14. dremu
    Feb 27, 2000
    15,952
    443
    I figgered you were asking Bob (Diesel4Me, whatever his real name is :) ... all I had was my trusty and vague HF digital caliper :)
    -- A
  15. goldwing2000
    goldwing2000 Guest
    The effort is appreciated! :bow:
  16. goldwing2000
    goldwing2000 Guest
    dremu, I just verified with a pitch gage that it is, in fact, 12 TPI. That's a helluvan eye you got there!
    Thanks again. :waytogo:
  17. diesel4me
    Jul 24, 2003
    17,537
    922
    Massachussetts
    no pitch gauge!..
    I don't have a thread pitch gauge!..:doah: --all I have as far as presision measuring tools is a plastic caliper that goes up to 6"!...I don't have much machine shop stuff,only some taps and dies...glad someone else was able to help!..:crazy:
  18. goldwing2000
    goldwing2000 Guest
    A decent tap & die set will come with a thread pitch gauge. That's what I used to check it.
  19. diesel4me
    Jul 24, 2003
    17,537
    922
    Massachussetts
    not mine!..
    I bought a bunch of taps and dies at a swap meet loose,in bins!..so no thread gauge yet!..I do have friends I can borrow one from though...dont have much use for one very often--most bolt sizes I already know what pitch they come in,I do have a tap drill chart that lists all the possibilities..GM seems to use weird size and pitch threads on things like pinion nuts,and tie rod sleeves and ends,and a few other things..and some are a regular size like 5/8,but have a weird pitch on the threads..one AM radio I lacked nuts for were 7/16x28 !..had to have them made at a machine shop,couldn't find any in boneyards!...
    :crazy:
  20. goldwing2000
    goldwing2000 Guest
    Got my 1 1/8-12 tap today! :woot:
    I need it for this project at work... yeah... at work. :whistle:
