Ball joint???
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by txguy, Feb 15, 2002.
  1. txguy
    txguy 1/2 ton status
    Sep 4, 2001
    114
    Round Rock (Austin) Tx
    TGIF!
    Anyone know what size nut it is that holds the lower ball joint on? I don't have the right end wrench, and need to go shopping... Does it tend to seize? I can get a hold of it, but doesn't budge... Next is go out and buy an end wrench to fit.
  2. outlaw612
    outlaw612 1/2 ton status
    Feb 11, 2001
    2,342
    Springfield, Illinois
    I just did mine last weekend, and I think its a 1 1/8". I had to break mine loose with a hammer and chisel.
    <a target="_blank" href=http://www.geocities.com/outlaw613/K5.html>http://www.geocities.com/outlaw613/K5.html</a>
  3. Triaged
    Triaged 1/2 ton status
    Feb 21, 2001
    3,808
    CA (LA/OC area)
    The top one is a 1-5/16 which is generally the one people don't have. If you are replacing just the lower you still need to take the top nut off and adjust the adjuster sleeve..
    '71 Blazer CST w/ a 400sbc, 4" lift, 36" Supper Swampers, and alot of rust
    <a target="_blank" href=http://community.webshots.com/user/triaged>See it Here </a>
  4. txguy
    Sep 4, 2001
    114
    I have the 1 1/8th. However, the wrench only fits halfway down and I have rounded off one edge at this point... Any ideas on how to remove that lower nut?
  5. outlaw612
    Feb 11, 2001
    2,342
    Do you have the spindle off yet? If so you should be able to pull the axle out and put a socket on the lower nut. I didnt realize this at first so i had to use a chisel and hammer to loosen the nut. Just put the edge of the chisel against the flat side of the nut and beat on it causing the nut to turn.(you need to apply the force towards the right side on the nut so it will turn the correct way)
  6. ftn96
    ftn96 1/2 ton status
    Sep 26, 2000
    3,238
    Nashville Tn
    1 1/8 is correct to the best of my knowledge. Its been a while since I did the swap/write up.
    Its the popping, rumbling, roaring, twisting, flexing, grinding, so you can wheel anywhere medicine[​IMG]
