Ball joint
Discussion in '1969-1972 K5 Blazer | Truck | Suburban' started by Rasberry, Jul 15, 2002.
  1. Rasberry
    Rasberry 1/2 ton status
    Mar 30, 2001
    205
    Orlando, Fl
    My lower drivers side ball joint is going on me. Can that be replaced without taking apart the wheel and pulling out the axle?
  2. 1 FN HI K5
    1 FN HI K5 1/2 ton status
    Aug 7, 2001
    465
    Northern CA Out in the stick\'s
    Nope I know that is not what you want to hear but NOPE. /forums/images/icons/frown.gif
    You should change both on whatever side is going bad.I had to press mine out on both sides when i did mine. Good luck /forums/images/icons/smile.gif <font color="red"> 1 FN HI K5 </font color>
  3. bouncytruck
    bouncytruck 1/2 ton status
    Oct 11, 2001
    858
    Bothell, WA
    I just changed the driver's side ball joints. The upper driver's side was completely shot (I had to grind the nut off because it was spinning freely in the socket.) When I took it into the shop to press it out, the guy said that the lower was going out too so I made a quick run to NAPA to pick up the lower. The shop charged me $19 to press them out and in.
