Ball joints 1982 questions
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by turbo, Sep 3, 2000.
  1. turbo
    turbo 1/2 ton status
    Feb 18, 2000
    109
    I have the new moog ball joints what other parts do I need to replace?
    Do I really have to remove the steering arm to the left side to replace the ball joints?
    Any other tips or advice?
    I want to make as few parts trips to town as possible.
  2. keith
    keith 1/2 ton status
    1,158
    La Fayette, GA
    I done the driver side the other night and it was easy BUT my knuckles were off the blazer so I can complete my cross over steering. All you need is the joints and the BALL JOINT PRESS and SNAP RING PLIERS for the external snap ring on the bottom joint. IF you have a compressor you can use the impact on the press and it will be easy. WD 40 or Liquid Wrench will help if you spray them down. Good luck
    If I missed something someone will let you know.
  3. Emmettology 101
    May 9, 2000
    8,126
    FL
    I use a hammer and a large socker that fits on the Ball joint ot "press" them in. I have done it this way a few time and without problems.
    While you're doing the Ball joints, check you Wheel u-joints, you may want ot replace those while you're in their.
    Also, check your wheel bearings and rotors since you will have all of these off and if they need replacing, now is the best time to do it.
    HTH
    Mike [​IMG]
    See <font color=green>EMMETT</font color=green> -&gt; http://emmett.coloradok5.com
