ball joints and axle shaft u joints
Discussion in 'The Garage' started by NEK5, Jul 14, 2006.
  1. NEK5
    NEK5 3/4 ton status Premium Member
    Oct 25, 2005
    9,843
    37
    Ipswich MA
    the front end i`m swappin in has a bad ball joint, so should i replace that side, upper and lower, or all four? which are the best to get? and while thats gettin done might as well do the axle shaft u joints...which are the best to get for these?
  2. goldwing2000
    goldwing2000 Guest
    If one ball joint is bad, might as well do upper and lower. If the other side is still good, don't worry about it.
    Moog or TRW for the ball joints.
    Spicer Life or Neapco Brute Force for the u-joints.
  3. divorced
    divorced 3/4 ton status
    Jul 20, 2004
    5,115
    I use the greasable Spicer joints in my axle shafts, although that's an unpopular choice around here.
  4. NEK5
    Oct 25, 2005
    9,843
    37
    Ipswich MA
    why is that?
  5. divorced
    Jul 20, 2004
    5,115
    Most guys like the non-greasables because they think the u-joint is stronger without the grease passages and they think the joint lasts longer because the grease passages clog up with dry grease and then the joint isn't greased properly. I pump mine until grease comes out of all 4 caps and haven't had any problems yet.
  6. NEK5
    Oct 25, 2005
    9,843
    37
    Ipswich MA
    so what do you recommend me getting?
  7. divorced
    Jul 20, 2004
    5,115
    Any wheeling I do is the mud and deep water, so I run the greasables. I don't run my truck real hard and don't do rocks, so strength usually isn't an issue. Either one should work fine for you.
  8. NEK5
    Oct 25, 2005
    9,843
    37
    Ipswich MA
    hmm, where would one buy these things? would autozone have em?
  9. goldwing2000
    goldwing2000 Guest
  10. Zeus33rd
    Mar 14, 2002
    7,324
    9
    Grass Valley, CA
    Non-greasable Spicers ARE stronger than the greasables. It's not because of the lack of grease passeges though... Most of the strength advantage of the Spicers non-greasables is from better material. Cold forged vs. hot forged. Cold forged material is stronger.:wink1:
  11. 4X4HIGH
    Dec 14, 2001
    22,060
    69
    Pleasanton, CA.
    With the Moog ball joints the upper joint has a grease fitting at an angle on the side so you don't have to tear apart the whole knuckle to grease the upper joint.
  12. goldwing2000
    goldwing2000 Guest
    Oooo... that's a nice feature. I wish I had known about that before I bought my TRWs. :doah:
  13. NEK5
    Oct 25, 2005
    9,843
    37
    Ipswich MA
    where can i get moogs?
  14. NEK5
    Oct 25, 2005
    9,843
    37
    Ipswich MA
    anyone have part numbers for the ball joints and axle shafts??
  15. NEK5
    Oct 25, 2005
    9,843
    37
    Ipswich MA
    ok...checked around, i can get moogs for 36 for uppers, 39 for lowers, and i can get trws at 28 for uppers and 34 for lowers, AAP has TRWs in stock, but the place that can get moogs needs to order them.....what do ya think?
  16. 4X4HIGH
    Dec 14, 2001
    22,060
    69
    Pleasanton, CA.
    It's your decision, is it worth the extra money and the wait time to order to not have to tear apart the whole knuckle to grease your upper ball joints?
  17. NEK5
    Oct 25, 2005
    9,843
    37
    Ipswich MA
    do moogs have any kind of warranty on them?the trws at advanced have a lifetime warranty, hmmm what if i went trw lowers, and moog uppers? would you recommend it, or should i go all moogs?
  18. NEK5
    Oct 25, 2005
    9,843
    37
    Ipswich MA
    are the axle shaft u joints also know as wheel joints?any brand have a warranty on them?
    also where would one get spicers? i noticed they have brute force ones at autozone with a 3 mon warranty
  19. 4X4HIGH
    Dec 14, 2001
    22,060
    69
    Pleasanton, CA.
    Moog is the best ball joint out there. I'm not sure what the warranty is on them but i thought they were 1 year. Doesn't really matter what kind of warranty there is, if you take care of them properly they will last a very long time.
    The front axle joints are just listed as "axle U-joints". Spicer is the best you can get in this item and people will argue one way or the other about grease fitting or not but i like them with a grease fitting so you can grease them and remove any contaminents and of course supply them with fresh grease.
  20. G.M.H
    G.M.H Registered Member
    Oct 6, 2002
    78
    wpg. mb canada
    Does anyone make a u-joint (besides CTM) that is greasable thru all 4 caps? Would it be possible to drill and tap the caps of a spicer joint for grease fittings, or are they too hard? It would seem that this would be the best setup, as it would eliminate the cross drilling, and thus the weakness of a greasable joint.
