Ball Joints going bad??
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by NAUBlazer, May 6, 2003.
  1. NAUBlazer
    NAUBlazer Registered Member
    Dec 3, 2002
    18
    Chandler, AZ
    Hey everyone,
    I have a question about a clunk i'm hearing. When I'm going pretty slow and I turn the wheel(ie backing out of a parking space) I hear a little clunk coming from the wheels it feels like. It happens about half way through the steering wheel motion. Could this be my ball joints??
    Thanks for the help
    --Adam /forums/images/graemlins/usaflag.gif /forums/images/graemlins/k5.gif
  2. 89GMCSuburban
    89GMCSuburban 1/2 ton status
    Nov 15, 2001
    3,005
    Thornton, CO
    Only one way to find out... jack up the truck, take the wheels off the front end. Grab your hubs and pull up and down on them, if they move, you need ball joints. I just got done doing this job. It's not too bad, it's just getting off the lower ball joint, took me 20 minutes on each with an air chisel with pickle fork attachment and lots of PB Blaster. If you end up doing them, buy the balljoints at Auto Zone, they're Perfect Circle (Dana) parts. Good luck!
  3. NAUBlazer
    Dec 3, 2002
    18
    Chandler, AZ
  4. 85 Shortbox
    85 Shortbox 1/2 ton status
    Jan 24, 2002
    138
    Grandville, Mi
    I found it is easier to jack it up like stated before and once the wheel is 4-6" off the ground use a board under the wheel for more leverage. This way makes it kind of a 2 man job but it will be easier to get movement this way if they are going bad. If not you don't have to d1ck with putting a tire back on. Good luck.
  5. opfor2
    opfor2 1/2 ton status
    Oct 28, 2002
    375
    Ventura County, CA
    Also check the leaf spring "U" bolts and make sure that they are tight. My blazer clunked and I found that the bolts were loose.
    Dan..
  6. NITRO
    NITRO 1/2 ton status
    Jan 9, 2002
    1,057
    Frankfort In
    my 1 ton p/u /forums/images/graemlins/truck.gifdoes this too. it makes a clunking sound. i figured it was just because it has 12" of lift. a BB, and 39.5" MT's. i guess ill check the u bolts. i dont have ball joints, so that can't b it. hmmmmm. got me thingking now
    NITRO
  7. LIFSVR7
    LIFSVR7 Registered Member
    Jan 16, 2003
    51
    NW Indiana
    Well, I am not sure if oyu have manual hubs, if not, then maybe it is like mine... Check the u-joints fromthe axle to the wheel.. I have manual, and the way I found out is when I had to drive 2wd (front wd) because I blew my spider gears /forums/images/graemlins/cool.gif /forums/images/graemlins/k5.gif /forums/images/graemlins/usaflag.gif
