Ball Joints
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by BUSCO, Mar 4, 2001.
  1. BUSCO
    BUSCO Registered Member
    Mar 4, 2001
    38
    New York(11552)
    Any suggestions on what ball joints hold up the best for Blazers with 6 to 8 inches of lift? Tried MOOG but had to replace two within 6 months.
  2. thatK30guy
    Jan 12, 2001
    32,076
    55
    I have gotten by fine with Car Quest joints. As long as they were greased, they were fine.
  3. CaptCrunch
    CaptCrunch 1/2 ton status
    Feb 2, 2001
    3,596
    Minnesota
    If you blew out Moogs or really any other name brand b-jt in a couple months you have other problems. Moogs also have a warranty (lifetime I believe) We have pulled them out after a car smacks a curb and breaks a Tierod end or if some idiot hooks it w/ a tow rope and it breaks. Never had any problems w/ our supplier taking them back. You running wheel spacers? Install them correctly (aka follow the instructions inclosed in the box not what you buddy says) ? Is the caster/chamber/alignment been done? Runnning shims in front?
    1987 Chevy K5 Blazer- 350 TBI
  4. 90K5
    90K5 1/2 ton status
    Jun 1, 2000
    3,719
    Lubbock, TX
    Did you set the preload on them? they will wear out very fast if you don't.
    90K5
  5. BlazerBoy
    BlazerBoy 1/2 ton status
    639
    Chicago IL.
  6. Executioner
    Executioner 1/2 ton status
    Feb 22, 2000
    1,530
    Temp. Ft. Walton Beach Fl. home=Tucson, Az.
    With a torque wench and a spanner socket.
  7. Blazer79
    Blazer79 1/2 ton status
    1,816
    Guatemala, Central America
    Could someone explain this in more detail? I will soon replace my ball-joints and want to do it right.
    <font color=blue>//////
    <A target="_blank" HREF=http://blazer79.coloradok5.com>http://blazer79.coloradok5.com</A>
    </font color=blue>[​IMG]
  8. SuperUnknown
    SuperUnknown 1/2 ton status
    Feb 8, 2001
    165
    Prince George, British Columbia, Canada
    I am also interested in the payload setting. I just got some new moog tierod ends today, and I don't want to screw them up. I thought you could just greas them up and slap them on.
    [​IMG]I spend more time under my truck then I do in it.[​IMG]
  9. Triaged
    Triaged 1/2 ton status
    Feb 21, 2001
    3,808
    CA (LA/OC area)
    Lift it, take the wheel off, and remove the steering arm tie-rod (use a Big F%@&ing Hammer). Attach a spring scale to the hole in the steering arm and record the pull required to keep the knuckle assembly turning after starting from the initial straight ahead position. The pull should be between 20 and 25 lbs in either direction. Adjust the balljoint by removing the upper balljoint stud nut and turning the adjusting sleeve. Reinstall the nut and tighten it to 50 ft-lbs. Than put everything back. This has all been plagiarized from a Haynes manual. Maybe you should buy one. lol
