ball joints
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by the fall guy, Jun 14, 2005.
  1. the fall guy
    the fall guy Registered Member
    Jul 1, 2004
    35
    I need to change my ball joints and I've pulled the rotors hubs all off before my question is when i take the axles out do they pull out or do i have to open the diff.
    Nick
  2. 88sub4x4
    88sub4x4 1/2 ton status
    Sep 22, 2002
    792
    Long Island, NY
    No need to pull the diff. apart. The axle halfs just pull out. Just be careful not to mess up the seals when you put the axle's back in.
  3. the fall guy
    Jul 1, 2004
    35
    I figured i would replace the seals while i have everything apart. Thanks for the info
  4. 88sub4x4
    Sep 22, 2002
    792
    Long Island, NY
    If you want to change the axle seals then you will have to pull the diff cover and remove the carrier. The seals are installed from inside the diff housing.
  5. fortcollinsram
    fortcollinsram 1/2 ton status
    Nov 8, 2001
    2,261
    Fort Collins, CO
    What was said before is correct...in order to replace the inner axle seals on the front axle you must remove the carrier after the axles are pulled honestly if you want to do them now is the time to do it since the axles need to come out anyways for the ball joint job.
    Chris
