ball joints
Discussion in 'The Garage' started by 2High4U, Dec 8, 2005.
  1. 2High4U
    2High4U 1/2 ton status
    Aug 20, 2005
    542
    Felton Pennsylvania
    Does anyone know if the factory ball joints on my 73 blazer are pressed in or can i get them out with a fork?
  2. 73k5blazer
    Dec 28, 2001
    4,987
    38
    The Rustbelt
    They are pressed in, they come out easy with the ball joint remover tool. (Looks like a giant C-Clamp). I think the tool is available at autozone or the like through their free rentals, and I know most rental tool places have it too. It was like $75 to buy.
  3. dremu
    Feb 27, 2000
    15,968
    461
    East of San Francisco
  4. divorced
    divorced 3/4 ton status
    Jul 20, 2004
    5,115
    My Autozone had the tool, but not the 4x4 adapters. It didn't work well, and using my impact wrench broke the clamp.
  5. Leper
    Leper 1/2 ton status
    Feb 18, 2005
    4,437
    Dallas Baby!!!!
    IIRC they are all pressed in. I use the cheap harbor freight tool(for everything). I have to file the threads on it every once in a while.
  6. sweetk30
    Nov 1, 2004
    25,552
    546
    horseheads , ny 14845
    need pics. i have never seen a broken b/j press from impact gun use. wow.
  7. MuddQueenK5
    MuddQueenK5 Registered Member
    Oct 15, 2005
    84
    Glenside, PA
    I just recently did mine last night. The C-Clamp method and mini sledge hammer method did not work at all for me. I had to go to my local car place and get them pressed out.
  8. divorced
    Jul 20, 2004
    5,115
    I don't have any pics, I just put it all back in the box and returned it to the Zone to get my deposit back. It didn't have the correct adapters, so I just let the end of the clamp touch the knuckle, but it wasn't square and broke some of the end off and cracked it. It wasn't break-in-half type carnage though.
  9. chasone64
    chasone64 Registered Member
    Dec 15, 2004
    88
    Oregon
    Same here & it works...
  10. spearchucker
    spearchucker 1/2 ton status
    Nov 17, 2003
    1,556
    Bay area, CA
    Not done from a impact gun but by hand. This is one of those b/j presses from Harbor Freight after about a half dozen uses. :rolleyes:
  11. 2High4U
    Aug 20, 2005
    542
    Felton Pennsylvania
    wow that is interesting never seen one of those break!
  12. mountainexplorer
    mountainexplorer 1/2 ton status
    Nov 14, 2001
    4,903
    Spokane, Wa./Ione, Wa
    So if you are able to take balljoints out and put new ones in with just a hammer and a pipe wrench, what does that mean?
    I was expecting to need a special clamp or press too, but somehow made it work with limited tools. Was I just lucky?
  13. diesel4me
    Jul 24, 2003
    17,580
    945
    Massachussetts
    lucky...??
    I've changed many sets of 4X4 ball joints..I have a crude homebuilt "press" thats just a rectangular square tubing frame made of tubing and two 3/4 threaded rods I can but a bottle jack in..but I only used it on cars and 2wd trucks a few times so far..most times they pop right out with a few blows from the BFH..they aren't a real tight press fit in most cases..even when I did use my "press",I only used muffler adapters as spacers to push the ball joints out,and they didn't even squash any..
    I've always been able to use my BFH and a pipe to get them in and out on 4x4's..so far anyway..have to use disgression when installing the new ones,don't beat the P*** out of them,and make sure they go in straight,and they will go right in..a little grease helps them slide in easier..that fancy tool is nice if you can afford a good one,like an "OTC" tool one,or Snap-On..don't waste money on China crap!..:crazy:
