ball joints
Discussion in 'The Garage' started by mbosmer, Oct 24, 2006.
  1. mbosmer
    mbosmer Registered Member
    Sep 6, 2006
    27
    Texas
    I need to replace my wheel bearings and ball joints and was wondering if there is any special tools needed to do the job 1987 K5 4x4
  2. Chaddy
    Chaddy 1/2 ton status GMOTM Winner
    May 23, 2005
    4,110
    Salt Lake City,Utah
    You will needa spindal socket, a ball joint press, and a big hammer, sometimes a torch, and dont install in the wrong order. You might as well do your u-joints in the axle shafts while your in there.
  3. 73k5blazer
    Dec 28, 2001
    4,987
    38
    The Rustbelt
    You'll need the magic hub (spindle) tool, to remove the wheel bearing retainers.
    You'll need a Ball Joint Press
    You'll need the Ball Joint sleeve removal tool
  4. goldwing2000
    goldwing2000 Guest
    The big hammer and torch that Chaddy mentioned is to remove the steering arm. It has to come off to get at the left upper ball joint.
    You're also going to need a torque wrench, if you didn't guess that already.
  5. 73k5blazer
    Dec 28, 2001
    4,987
    38
    The Rustbelt
    Really? :confused: I never removed my steering arm, I've done several D44's. Never did a D60, those have Kingpins though. Never any problems getting to it.:confused:
  6. Chaddy
    May 23, 2005
    4,110
    Salt Lake City,Utah
    I actually put the heat on the ball joint itself....
  7. mbosmer
    Sep 6, 2006
    27
    Texas
    Where would be the best place to get the tools?
  8. goldwing2000
    goldwing2000 Guest
    That's strange. I've never been able to get the receiving sleeve past the steering arm. Do you do your ball joints with a ball joint press or a hydraulic press?
  9. 73k5blazer
    Dec 28, 2001
    4,987
    38
    The Rustbelt
    The ball joint press,just like the one pictured.
  10. goldwing2000
    goldwing2000 Guest
    Cool. I'll have to try that next time. Taking that damn steering arm off is a pain in the ass.
    mbosmer: You can usually find the tools at any decent auto parts store. You can rent the ball joint press but I would recommend buying the spindle nut socket. You'll need it again.
  11. 86dieselburb
    86dieselburb 1/2 ton status
    Oct 20, 2004
    219
    Crestline, CA
    Ok since I'm in the same boat, needing to replace ball joints on me 44. Can someone explain the process to preload the upper balljoint? I'm sure the originating poster would need this info as well.
  12. 86dieselburb
    Oct 20, 2004
    219
    Crestline, CA
    Ok found how to do it. Pretty simple.
    "Then you need to install the Ball Joint adjusting sleeve (also called upper ball stud split ring seat) into the top of the yoke and tighten that down to 50 Ft-Lbs using a special spanning wrench which (Product # T40207) I bought at 4wd.com for $20. This sleeve is meant to set the pre-load on the ball joint."
    http://members.cox.net/rough-riders/tech_page/dana30/dana30.html
  13. goldwing2000
    goldwing2000 Guest
    Yep. Don't forget to torque the lower to 30 ft-lbs first.
