Balljoint snapring missing
Discussion in 'The Garage' started by G.M.H, Nov 12, 2006.
  1. G.M.H
    G.M.H Registered Member
    Oct 6, 2002
    78
    wpg. mb canada
    I recently changed the balljoints on my 1980 10-bolt front. I just noticed that the snapring on one upper joint is broken and half of it is missing.
    Is this a safety concern, or could it cause problems on the trail?
  2. Confedneck79K30
    Confedneck79K30 3/4 ton status
    Oct 1, 2006
    5,384
    LA
    replace it, they're press fit, but that only would break if it moved or shifted enough to unseat or crack that snapring, so re-seat the balljoint and install a new snapring...
  3. goldwing2000
    goldwing2000 Guest
    Every upper ball joint I've ever seen (a couple dozen of them) never even came with a snap ring. Only the lowers.
    As long as your preload is properly set and your lower snap ring is still in place, I wouldn't worry about it.
