Balljoint wont take grease
Discussion in 'The Garage' started by MTBLAZER89, Dec 29, 2005.
  1. MTBLAZER89
    MTBLAZER89 3/4 ton status Premium Member GMOTM Winner
    Aug 14, 2001
    7,272
    237
    Oak Harbor, WA
    Anybody ever had this prob before? It's the upper joint. The little ball in the zerk was pushed up and it was kinda rusty. I tried a different zerk, but still no joy:confused: Anybody have a cutaway of a balljoint? Could there be rust plugging a small passage or something? I am gonna buy a needle tip tomorrow. Is it possible to just squirt grease in there to fill the cup? Any advice??
  2. 73k5blazer
    Dec 28, 2001
    4,987
    38
    The Rustbelt
    Does the zirk stay in it's hole when you pump grease? I used to have mid-'90's polaris snowmobile that had press-in zirks and they would always pop out while pumping grease. I tapped the holes an replaced the zirks with threaded models.
  3. MTBLAZER89
    Aug 14, 2001
    7,272
    237
    Oak Harbor, WA
    Yeah the zerk stays in there. I swapped in a known good zerk from another joint that I just greased.:dunno:
  4. mxfireman
    mxfireman 1/2 ton status
    Dec 7, 2002
    2,480
    LHC, AZ
    sounds like the ball joint has a bunch of #$%^$# in it.....might need to replace it.
  5. Robert D
    Robert D 1/2 ton status
    Oct 2, 2005
    261
    Austin, TX
    Could the bushing on the joint be cracked and blocking the hole? My only experience with balljoints are on a 944, and the bushings seemed to fail pretty regularly.
