balljoint ?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by cegusman, Feb 1, 2002.
  1. cegusman
    cegusman 3/4 ton status
    Apr 25, 2001
    6,793
    Houston/Katy, Tx
    I am doing my ball joints rights now, the problem is the lower ball joint nut spins with the bolt how do I get it off?
    Houston, TX
    <a target="_blank" href=http://community.webshots.com/user/cegusman>http://community.webshots.com/user/cegusman</a>
  2. If you're not using air with a good air gun then you might need to soak the heck out of it with some penetrating fluid
    Later...
    4 wheelin's not a job, it's an adventure!
  3. ftn96
    ftn96 1/2 ton status
    Sep 26, 2000
    3,238
    Nashville Tn
    Take a floor jack and jack up on the bottom end of the Ball joint. This will help hold it in place while your turning the wrench on the nut!!!
    **WARN**ing, Something winching this way comes! [​IMG]
    <a target="_blank" href=http://www.mccords.s5.com/myk5/index.htm>NashvilleK5</a>
  4. Triaged
    Triaged 1/2 ton status
    Feb 21, 2001
    3,808
    CA (LA/OC area)
    I tried all the stuff that was said above and mine still didn't come out. I drilled 2 holes down thru the nut and than split it in 2 with a chisle. It didn't take long at all but I broke a bit because the nut span when I was drilling it.
    '71 Blazer CST w/ a 400sbc, 4" lift, 36" Supper Swampers, and alot of rust
    <a target="_blank" href=http://community.webshots.com/user/triaged>See it Here </a>
