balljoints?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by wheelin247, Sep 17, 2000.
  1. wheelin247
    wheelin247 1/2 ton status
    Aug 29, 2000
    178
    hayward,ca
    are balljoints easy to repiar urself or do u have to take it to a shop to have it done?
  2. sosamantx
    sosamantx 1/2 ton status
    Aug 14, 2000
    393
    somewhere in Texas
    <font color=blue>They are not real easy, but they are do-able. If they have never been changed before then you might have to drill or pop out the rivets that are holding in the stock ones. - Steve</font color=blue>
    <font color=blue>Steve Sosa a.k.a. "sosaman"</font color=blue>
    http://sosaman.home.texas.net/carpics.html
  3. MA87K5
    MA87K5 1/2 ton status
    Apr 6, 2000
    558
    Chicopee, Ma 01020
    "AS stated in a later post on ball joints." Changing out the ball joints should take a couple of hours per side, maybe longer depending on the experiance. There isn't any rivets to drill out though,they are on non 4x4 vehicals. I think that it is alot easier then changing them on a non 4x4. There is no spring pressure on the ball joints. If you have air tools then you are going to be happy.You'll also need a spindle socket, maybe a four prong one. After you put the ball joints on the spindle and connected to the axle housing and bolted down, grease the upper joint before you put the axle in. Because the grease fitting will hit knuckle on the axle. The ball joint should come with a plug to take place of the fitting after it is greased. The job isn,t all that hard. Hope I helped any.
