Bang and Shake
Discussion in 'The Garage' started by icedragon, May 19, 2006.
  1. icedragon
    icedragon Registered Member
    Sep 6, 2005
    18
    connecticut
    Ok i need some input here
    I just came back from the local gas sattion about a block away, on teh way back i started getting a bang and a shake from the reaar of my k5, this happened all the way home. I crawled under neath (of course the driveway is a lake right now) and the driveshaft seems ok, all the u joint cupas are there. its a 10 bolt rear any clues?
    well i had to move it in the driveway, i no longer can shift into 4l or n
    could it be my tcase is shot instead of the rear axle? i believe its an np241
    thanks
    rich
  2. NEK5
    NEK5 3/4 ton status Premium Member
    Oct 25, 2005
    9,843
    37
    Ipswich MA
    check your lugs:D
  3. icedragon
    Sep 6, 2005
    18
    connecticut
    jsut checked lugs they are all there and tight
    a friend called and i aksed him since he's a gm nut and he suggested the spider gears may be missing a tooth or 2
  4. resurrected_jimmy
    May 23, 2005
    2,241
    back home in Houston
    X 1000
    If it has a gov-bomb in the diff, it just quit. You need to open it up and look in there before you do anymore damage
  5. yoshisv
    yoshisv 1/2 ton status
    Feb 19, 2006
    266
    Hartsville, Tennessee
    I had trouble with the carriers breaking in 10 bolts with 33 inch tires. It would snap the collar that the bearing rides on off. when they broke it would do just as you described.
  6. icedragon
    Sep 6, 2005
    18
    connecticut
  7. resurrected_jimmy
    May 23, 2005
    2,241
    yes its possible, unhook the drive shaft, put the tranny in neutral and spin the t-case by hand to see if it feels smooth. pull the drain plug and see if metal shavings come out in the oil.
    Also try jacking up the rear end and spin a tire by hand, you may be able to hear or feel broken parts rolling around in there
  8. icedragon
    Sep 6, 2005
    18
    connecticut
    ok we've determined it's the t-case thats shot
    i ahve a friend with an np208 that came from his 70's k5
    i believe his had a 700r4 as well, question is will the 208 bolt right in and be a direct replacement or do i need to change the front driveshaft or anything else?
    thanks
    rich
  9. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    If you had a 700r4/241 , then the 700r4/208 will directly bolt up . Your year was mechanical speedometer so your good to go there too .
    Beware though that a used 208 is used . The parts that wear and cause shifting trouble could be worn if the case was wheeled or worked often ( in and out of 4wd ) .
