bang bang bang
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by jimmylake, Oct 27, 2002.
  1. jimmylake
    jimmylake Registered Member
    Oct 25, 2002
    5
    west miochigan
    just picked up an 85 s10 blazer. It has the 262 engine. thought it had a rod knocking. now i am sure it is coming from the flywheel (flexplate) maybe a broken bolt, broken flex, etc. not sure. there doesn't appear to be an inspection plate to look at the flywheel. i suppose than means it has to come apart. anybody else ever have this problem.
  2. DieselDan
    DieselDan 1/2 ton status
    Jan 27, 2001
    1,056
    Vermont
    My '89 Jimmy w/ a lock-up style converter 700R4 was knocking something fierce.
    That was my initial thought the flexplate must be cracked. But after pulling the inspection cover I couldn't see anything wrong.
    The knocking would come and go (after a couple of weeks it was routine). It would knock in D, R, OD, N, 1, couldn't hear it at speed. It seemed as the lock-up would "recenter" the bearing and the knocking would cease for a little while.
    Diesel converter cost double the gas version, ouch. /forums/images/graemlins/shocked.gif
