Banjo bolt torque
Discussion in 'The Garage' started by broc944, Mar 26, 2006.
  1. broc944
    broc944 1/2 ton status
    Sep 23, 2005
    1,660
    Northern Minnesota
    Just got done bleeding the barakes for the 14b disk conversion. I had a small leak on both Banjo bolts, snugged them down some more and it seems to have stopped, but time will tell. What is the torque setting for this, (and please do not tell me to tighten them till it stops).
  2. Muddytazz
    Muddytazz 1 ton status
    Jun 30, 2002
    20,073
    Salem, Or.
    It's actually only 22 ft/lbs
  3. ryoken
    Jun 13, 2003
    29,622
    1,375
    Jersey Shore
    think the book calls for 22 lbs... Did you replace the crush washer?
  4. MattK
    MattK 1/2 ton status
    Jan 12, 2005
    1,713
    Dallas, TX
    yeah make sure you got those.
  5. broc944
    Sep 23, 2005
    1,660
    Northern Minnesota
    Yea, they are replaced everything was new, just checked I have 30lbs and they stopped leaking, think I will leave it at that, thanks for the info.
  6. Muddytazz
    Jun 30, 2002
    20,073
    Salem, Or.
    Are you using an old or new banjo bolt? Over-torquing can cause leaking also.
  7. broc944
    Sep 23, 2005
    1,660
    Northern Minnesota
    Those are new also, they are not bottoming out either in the caliper, I torqued them in 5 lb increments, at 20 it was a drip, 25 they weeped, and at 30 it stopped, and after the test drive I checked again and it was OK. It is a new torque wrench not a super expensive one, but not a cheapy either. I was really pumping on the brakes to get the pressure up to check for any leaks also.
