Banks install photo
Discussion in '1982-Present GM Diesel' started by DukeBoy88, Jun 29, 2006.
  1. DukeBoy88
    DukeBoy88 1/2 ton status
    Oct 16, 2002
    315
    Jonestown Pa
    I hope this is the right way to post a photo.
    http://coloradok5.com/photos/showphoto.php?photo=13631
    This is my after photo of my Banks Sidewinder install. I modified some of the banks pieces and rerouted some of the lines from the instructions, heater, CDR, etc. I gasket matched the heads and intake, and then polished the intake and thermostat housing with a wire brush and scotchbrite. coated it with eastwood clear. coated the exaust manifolds with eastwood hi-temp ss paint. painted a couple pieces camo. fabricated a mount for the racor and battery hold downs, and other brackets out of scrap stainless. eliminated the mechanical fuel pump and ran lines down the drivers side. converted to 12v, made new cables out of 0/2 installed a gear reduction starter and Kennedy diesel glow plugs and return lines. made an overflow tank out of a german 1gal fuel can (looks like a smaller jerry can) replaced all motor mounts with poly. installed a TCI aluminum deep pan on the tranny and installed a temp gauge in the out line (adding a B&M cooler next). added other mechanical gauges and repaired my frame at the steering box with ORD's kit.
    And some other nickel and dime stuff along the way. truck runs good, I'm very happy, I'll still be tweaking it for a while I'm sure. Next will be the diesel conversion on the K5.
  2. k5blazin
    k5blazin 1/2 ton status
    Dec 19, 2004
    262
    Elizabethtown, PA
    Congrats! looks good! Your semi close to me... think we can meet up and you take for a spin in that beast?? Id like to know what a turbo 6.2 can do before i do mine.
  3. tRustyK5
    Jul 23, 2000
    36,169
    1,366
    E-town baby!
    Very nice work!!
    Rene
  4. DukeBoy88
    Oct 16, 2002
    315
    Jonestown Pa
    Yeah that shouldn't be a problem, although I don't know if it earns the name beast quite yet, definatly respectable, and a great improvement over NA. I would like to know the limits of dependable power available from a 6.2 without lowering the compression. I think an intercooler would be my next step.
