banks power or 454 swap
Discussion in 'The Garage' started by general blaze, Nov 13, 2006.
  1. general blaze
    general blaze 1/2 ton status
    Sep 4, 2005
    128
    ca
    ok so i have a 83 blazer with the 6.2 i am not happy with the power so i am going to do something about it. should i spend the cash and get a banks sidewinder kit. or just throw in a 454 that i have sittin in the shop.
    i go to glamis alot and i am getting pretty mad that these stupid little toyota trucks and little rhino golfcarts are making it up olds and i am not.. this is not cool. anyway let me know what you guys think.. i want this to happen soon.\
  2. bigblock72
    bigblock72 1/2 ton status Premium Member GMOTM Winner
    Oct 18, 2005
    1,235
    59
    American Fork, Utah
    The 6.2 will never be much of a dune runner. You need to get away from the nasty oil burner and get yourself a motor that'll run. The big block will easily outdo the 6.2 in every way (except fuel milage) and if it has some go fast goodies it should take you wherever you want to go and beat some of those loud obnoxious golf carts.
  3. steve_kibbe
    steve_kibbe 1/2 ton status
    Feb 4, 2004
    2,895
    Spartanburg, SC
    I'd sell the 6.2 blazer and buy a gasser. I'm sure one of these oil burner guys would love to buy a factory diesel K5.
  4. colbystephens
    colbystephens 1 ton status GMOTM Winner
    Feb 24, 2005
    10,924
    20
    Oregon
    what's your set up? i assume a 6.2/700/208 w/ what gearing?
  5. general blaze
    Sep 4, 2005
    128
    ca
    i dont know what you mean about those numbers. it is a stock set up. it has high gears no low end power. it is a 6.2 and i have no idea what gears i have but i want to change axels and gears asap.
  6. colbystephens
    Feb 24, 2005
    10,924
    20
    Oregon
    i'd bet you've got 3.42's or 3.73. the biggest problem with the diesel set up is that they typically come with very poor gearing. that vehicle was designed solely for fuel economy, thus the high gears. before you put money into a turbo or a new engine, find a set of axels w/ 4.10 or 4.56 gears and then see how that truck performs - i bet you'll be surprised. ever thought of going to a manual transmission? that will increase the amount of power you feel significantly too. i've got a 6.2 w/ a manual and 4.10s on 35's, and it gets me up and going as fast as i'd ever want it to.
    edit. those numbers i listed out: 6.2/700/208 stand for 6.2L diesel engine/700r4 transmission (automatic w/ overdrive)/np208 transfercase. ;)
  7. SHAPER
    SHAPER Registered Member
    Oct 11, 2006
    68
    Western PA
    Well, if you got a 454 sitting around...I woudl think its a no-brainer. ;)
  8. blazinzuk
    blazinzuk Buzzbox voodoo Premium Member GMOTM Winner
    Dec 20, 2002
    17,412
    3,799
    Afton / Star Valley Wyoming
    IMHO diesels don't rev enough to be a really good dune runner. I think it would help a ton though if you got the banks sidewinder kit. I am a fan of diesels and would love one to wheel, but if it was mostly sand then I would have to say go with the gas motor.
  9. colbystephens
    Feb 24, 2005
    10,924
    20
    Oregon
    that's probably right. i don't know anything about glamis...
  10. DesertDueler2
    DesertDueler2 1/2 ton status
    Dec 25, 2004
    132
    Chandler, AZ
    Yea, except in glamis there are some sick dodge diesels. But if your staying chevy, I would recomend a small block over a big block. That is alot of weight. I would also lighten your truck as much a possible. Big heavy trucks have a hard time going u olds hill. Put a small block in it, and 4.56 gears and keep the rpms up.Dan
  11. DesertDueler2
    Dec 25, 2004
    132
    Chandler, AZ
    Also getting some paddles will help too.Dan
  12. resurrected_jimmy
    May 23, 2005
    2,241
    back home in Houston
    a BBC doesn't weigh that much more than a SBC, since you have one sitting around run it. As already said it may be worth selling your truck and getting a gasser if you don't have a lot tied up in you current rig
  13. DesertDueler2
    Dec 25, 2004
    132
    Chandler, AZ
    A big block is 150 lbs heavierDan
  14. twodollars
    twodollars Registered Member
    Jul 19, 2006
    49
    Wayne, MI
    I went the other way with my burb - 454 tbi to 6.5. But I added a blower instead of the turbo. With some careful consideration of parts, the 6.5 will make great power and torque. I have a 88 burb with a 6.5 and the banks kit (used to be a 6.2). Once up on boost, it really comes alive. But the banks turbo is a little loose, and takes some time to spool up. I'm planning on a different turbo with a waste gate in the future.
