Barn door conversion
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Woodman89, Feb 12, 2002.
  1. Woodman89
    Woodman89 Registered Member
    Jul 27, 2000
    60
    New Hampshire
    A friend of mine has a 89 burban with a tailgate. The truck is pretty nice but hates the tailgate and wished it had barn doors. Has anyone ever converted from tailgate to barn doors on a burban? can it be done? I would imagine that chevy did not make two completely different bodies for doors/tailgate. I figured that if anyone would knew it would be the people that hang out here!
  2. ColAdo82K5
    ColAdo82K5 1/2 ton status
    Feb 18, 2000
    789
    MO
    hey,
    I've never done it but i've heard of people who have. The biggest thing is that you must have every little part off of the donor vehicle. this includes the limit straps and latchs in the center of the opening and everything.
    It should bolt right in.
    Blake
    Who needs new parts when there are junk yards and hardware stores ?
  3. Mudstud
    Mudstud 1/2 ton status
    May 29, 2001
    1,472
    Memphis, TN
    Grim might have SOME insight since he built custom barn doors for his k5. Just a thought.
    Mudstud
    <a target="_blank" href=http://communities.msn.com/OffroadK5s/6superliftand33s.msnw>http://communities.msn.com/OffroadK5s/6superliftand33s.msnw</a>
    76K5 6" with 33s, sb400/350/203parttime/3.73-D44/GM12bolt
  4. 502Burban
    502Burban 1/2 ton status
    Jun 8, 2001
    379
    Southern California
    I'm in the process of doing this to my '73 right now. It isn't too tough to do; just need to get all the parts. I found a good wrecking yard with some helpful people who pulled some barn doors from a donor vehicle and made sure to get all the little pieces. If you don't get all the small stuff (latches, hinges, rubber bumpers, straps, wiring harnesses for defroster &amp; lock, etc, etc) the swap will nickle and dime you to death.
    The one thing to watch out for is that you need to replace the lower sill assy. It has a recessed area that accomodates the lower latches, instead of the holes for the tailgate hinges.
    I don't have it handy right now, but if you are interested, I can supply you with the correct GM part number for the sill. I think it cost about $200 from the Chevy parts counter, but can confirm that later also.
    Just let me know,
    Robb
    <a target="_blank" href=http://community.webshots.com/user/robbrj>'73 GMC Suburban - 502DFI</a>
