Barn Doors to Tailgate?
Discussion in '1936-Present Suburban' started by or2play, Jul 27, 2002.
  1. or2play
    or2play 1/2 ton status
    Feb 22, 2002
    665
    Yuma, Arizona
    My barn doors need a lot of work. Thought about changing them to a tailgate. Anyone ever done it?. Thoughts or ideas......
  2. Ddragggon
    Ddragggon 1/2 ton status
    Apr 25, 2001
    2,660
    Hartford, WI (formerly Etiwanda, SoCal)
    I can say I prefer the tailgate to the doors, although I';ve never done the conversion...
    get the complete tailgate assembly from a donor vehicle, including the `helper spring' torshin bar... without that thing, you get to feel all 140 Lbs of steel, everytime you want to close that thing. ( I know this, because the previous idiot cut the torshin bar to pull teh gate at some point, and I;ve not had one in forever)
    all the nessicary holes to put the tailgate on are already there... oh, and don't forget the fiberglass upper cowl that the window rolls up into, or you'll not be very successful in the functionality endevors...
    -Rich
  3. 502Burban
    502Burban 1/2 ton status
    Jun 8, 2001
    379
    Southern California
    I am going the opposite direction (tailgate to barn doors) and can probably give you a tip that will help. The part of the conversion that kinda caught me by surprise is that the two configurations use different door sills.
    The tailgate sill has cutouts to accomodate the hinges, whereas the barn door sill has a sunken area to accomodate the lower door latches. I purchased a new one from GM to swap so that the barn doors I picked-up will fit.
    Other than that one issue, it's pretty much of a straightforward swap. Just try to find a donor vehicle that you can get all the miscellaneous little bolts, hinges, torsion bar, trim pieces, etc. from.
