base timing setting 5.7l
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 1badv10, Mar 8, 2004.
  1. 1badv10
    1badv10 Registered Member
    Feb 26, 2004
    74
    new york
    my truck has had an engine change from 5.0-5.7, the base timing setting for the 305 is 0 degrees (i think).. is this the same for a TBI 350? I put a performance CPU chip in and im getting detonation at WOT w/ 93 octane and a 160 thermostat, so i just wanted to verify the base timing before i yank the chip out.... /forums/images/graemlins/thinking.gif thanks...
  2. big83chevy4x4
    big83chevy4x4 3/4 ton status
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    i know on carbed it is 4 for 305 and 6 for 350 /forums/images/graemlins/dunno.gif i would adjust the timing till it goes away
  3. BurbinOR
    BurbinOR 3/4 ton status
    5,829
    Oregon
    Base for my '91 TBI 5.7 is 0* also. Might your compression be higher than stock? Is your knock sensor working (can you scan it and tell)?
  4. southernspeed
    Dec 24, 2003
    4,395
    50
    VA
    Ditto that info. /forums/images/graemlins/thumb.gif
  5. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    I would look into making sure the knock sensor is ok. It shouldn't knock. The computer should retard the timing as soon as it detects pings.
    Harley
  6. 4X4HIGH
    Dec 14, 2001
    22,060
    69
    Pleasanton, CA.
    Did you make sure you disconnected the tan (EST) wire before setting base timing?
  7. 1badv10
    Feb 26, 2004
    74
    new york
    thanks guys 0 degrees it is.. checked the timing this morning its set to 5-6.. really wish i could find my damn distributor wrench /forums/images/graemlins/doah.gif . but being advanced plus the cpu chip is advancing it more.... im going to put the 5.7 knock sensor, and a heated o2 sensor in this week, it may run as good as it did before i started f#@king w/ the performance mods /forums/images/graemlins/whistling.gif again thanks guys
