basic axle/t-case questions
Discussion in 'The Garage' started by thesaint, Dec 21, 2005.
  1. thesaint
    thesaint Registered Member
    Nov 13, 2003
    6
    San Diego, Ca
    Does anyone know if there Was ever a 6 lug version of the 14 bolt rear axle? maybe even the right length to fit my first gen K5?
    also
    Does anyone have any experience with the alloy case version of the 205 transfer case that chrysler used a while back? how much weaker were thay then the cast iron version (and how much lighter?) are they adaptable to a gm drivetrain?
    thanks and a great holiday to all.
  2. rick88blaze
    rick88blaze 1/2 ton status
    Jan 24, 2003
    2,342
    Knob Noster, Mo.
    I don't know about the t-case, but there is a 6 lug version of the 14b semi-float out there. One from the late 80's early 90's should be a direct bolt in. :D
    Rick
  3. u2slow
    u2slow 1/2 ton status
    May 9, 2001
    2,217
    BC Canada
    Not a bolt-in. Moving perches and shock mounts will be necessary.
    Alloy case 205?! All the Dodge ones I've seen are iron. Maybe you're thinking of the 208 or 241... the chrysler versions were fixed yoke.
  4. rick88blaze
    Jan 24, 2003
    2,342
    Knob Noster, Mo.
    I believe that as long as it comes from up to a '91 4wd he shouldn't have to move anything. :dunno:
  5. sweetk30
    Nov 1, 2004
    25,526
    526
    horseheads , ny 14845
    73-91 old body was 8 lug semi float only. 88-up new body is 5-6-8 lugs wider axle and need to move perches and shock mounts like said.
  6. rick88blaze
    Jan 24, 2003
    2,342
    Knob Noster, Mo.
    My bad, I thought there were some 6 lug ones out there that were straight bolt in.:doah: :whistle:
