basic newbie with some questions!!!!
Discussion in 'The Garage' started by dsmd58, Nov 20, 2005.
  1. dsmd58
    dsmd58 1/2 ton status
    Sep 18, 2005
    624
    Glad to be here.....so here it is....bought a 78 k10, lifted about 6" with rough country blocks (ugh) so the driveshaft angles were out of whack. The rear yoke at the tranny/t-case broke off an ear, and BOOM goes my driveshaft......
    So I have a few questions....(since I am new to this truck)
    1 - Is there a good company to get a front or rear driveshaft made that anyone knows of?
    2 - How can I identify my T-case? 203 or 205? I want to buy the correct yoke to replace the broken one....
    3 - If I do not get a custom one made, is there any quick fixes to correct the driveshaft angles? (I heard you could remove the tranny mounts, and bolt it to the crossmember, giving you a better angle for the front/rear driveshaft...true?)
    Thanks!
  2. wforicv
    wforicv 1/2 ton status
    Feb 16, 2004
    165
    Back in Augusta, GA again
  3. dsmd58
    Sep 18, 2005
    624
    Thanks! Will do.....Pete
  4. blackblazer717
    blackblazer717 1/2 ton status
    Jul 1, 2004
    470
    massachusetts
    most stuff here is pritty much just search and find, you will find 90% of what you are looking for!
    a cheep way to fix your d-line angle is with some rear axle shims BUT you said you have some huge blocks, or a couple stacked on top of eachother.
    best bet is remove the blocks and put a 2 inch block in and than go to
    www.offroaddesign.com and get their 4 inch shackle flip kit. best thing in the world, it will help your angle as well, along with dropping the t-case
    LUKE
