Basics of WinALDL
Discussion in 'The Garage' started by grindkings, Jul 15, 2005.
  1. grindkings
    grindkings 1/2 ton status
    Dec 24, 2004
    127
    Marshall, Missouri
    Can someone explain WinALDL to me, where to get it and how to make a cable?
  2. scrappy88
    scrappy88 1/2 ton status
    Mar 14, 2003
    314
    Loveland, CO
    www.winaldl.webhop.net
    Everything you need to know about the program and how to make the interface cable. :thumb:
  3. grindkings
    Dec 24, 2004
    127
    Marshall, Missouri
    Has anyone found this to be a lifesaver for perforance TBI motors?
  4. Triaged
    Triaged 1/2 ton status
    Feb 21, 2001
    3,808
    CA (LA/OC area)
    I just started playing with it on my "perforance TBI" 2.8L v6 in my s10 :haha: . About all I can tell just by looking at it the little I have is that it is running a bit rich. I need to pull off the exhaust and put in my Wide-Band O2 sensor...but it is too hot right now and I am lazy.
  5. dyeager535
    26,979
    It worked enough in my application (close enough for your question) to tell me that my unheated O2 sensor is not up to the task, which is contrary to what I thought before hooking my laptop up to the ECM via winALDL.
  6. grindkings
    Dec 24, 2004
    127
    Marshall, Missouri
    What are the differneces in the modes? And which one do I want to use in "changing" things for my new motor?
  7. FWP
    FWP CRS
    Oct 11, 2000
    3,845
    3
    Prescott Valley, AZ
    You can't change anything. WinALDL is a troubleshooting/ monitoring tool. Best advice is to spend many hours on Thirdgen.org and other sites to understand things.
  8. grindkings
    Dec 24, 2004
    127
    Marshall, Missouri
    Okay?...Then how do i get my motor to "get along" with the ECM? And change fuel curves.
  9. grindkings
    Dec 24, 2004
    127
    Marshall, Missouri
    This program appears to be confusing. I see that you can change the TPS. What will that do? I have a Holley TBI, can some just TELL ME WHAT TO DO.
  10. Russell
    Russell LB7 Tahoe Status Premium Member GMOTM Winner
    Jun 23, 2000
    7,923
    333
    Fort McMurray, Alberta
    You cannot actually change anything with WinALDL, you need to buy a chip burning tool if you wanna make modifications. The TPS is adjusted by physically adjusting the sensor itself :) WinALDL is for watching, and trouble shooting problems, not for actually editing the prom :)
  11. dyeager535
    26,979
    Go download tunerpro RT, and start playing with that. THAT is the software used to make changes to a PROM. Not the only one, but it's free.
    winALDL is what you use to see how your engine is acting. What the MAP is showing, where your TPS is, O2 sensor voltage, BLM's, INT, etc.
    As was mentioned, once you get data from your ECM via winALDL, spend time over on thirdgen understanding what all the different fields mean. Once you understand what indicates rich/lean, knock, etc., you'll start to see what each piece of data you see in winALDL is telling you about how the engine is running, and what the ECM is having to do to keep it where it wants to be, if it even can.
  12. grindkings
    Dec 24, 2004
    127
    Marshall, Missouri
    What am i looking for at thirdgen.? I've spent some time over there and can't find anything, just about firebirds. Am i missing it?
  13. dyeager535
    26,979
    Ignore what the vehicle is. Go to the DIY PROM forum, read the stickies, perhaps search for threads regarding the 1227747 ECM, which is what will be in your truck. I suspect the cars used the same for a few years of TBI.
    Might also check the TBI forum, but that is more likely about performance stuff, not understanding how to modify the PROM.
    Only physical difference in the F-body TBI and yours that I can recall is going to be that the cars used a manifold air temp sensor (MAT) and trucks didn't. Oh, and EGR is apparently not controlled with a solenoid in the trucks.
    Here's just one link to a sticky about burning your own PROM's, etc. Tuning/performance stuff for injected setups.
