Bass Blockers advice needed.
Discussion in 'Audio' started by Z3PR, Apr 18, 2005.
  1. Z3PR
    Z3PR Banned
    Mar 30, 2002
    19,217
    Everywhere
    Okay, with these speakers, what bass blockers should I use. I've seen some 100 hz and 300 hz bass blockers. I know practicly nothing about this stuff, so I'm asking advice from you guys that do know about this stuff.
  2. PhoenixZorn
    PhoenixZorn 1/2 ton status
    Mar 17, 2005
    1,734
    West Allis, WI
    Why do you need bass blockers?? 4x6 speakers shouldn't even find themselves in the 100-300Hz range... Thats what MidRange and SubWoofers are for. You are buying full range speakers, you shouldn't have to worry about them hitting those low frequencies unless you wire them up to the midrange channel. If you want to do it right, just recut your speaker holes for 6 or 6.5 inch speakers, get a high quality amp, and a single 10 or 12 inch subwoofer.
  3. Z3PR
    Z3PR Banned
    Mar 30, 2002
    19,217
    Everywhere
    Can't cut the doors in this car. Everything must look factory. Car is 2000 Oldsmobils Alero GLS coupe (2-door). Want bass blocker too keep the lower range out of these speakers just so they'll last long. (I do like it loud) Will hook up a pair of 12" Kicker L7's in a slot port box sometime in the next couple of months.
  4. seschev3
    seschev3 1/2 ton status
    Jan 19, 2005
    308
    clayton, ca
    Put 200-300's on the 4x6's. 100's are for 5.25" and 6.5" speakers. Without a decent air tight enclosure for the 4x6 the bass will fry the voice coil. Cap em off and leave the bass to the 12".
  5. Z3PR
    Z3PR Banned
    Mar 30, 2002
    19,217
    Everywhere
    Talked to my car stereo shop and they recomend a amp with a hi pass crossover and forget the bass blockers. Probley do that. Just have too suffer with the factory speakers till I can afford those JBL speaker and Orion 8004 amp to power them.
  6. seschev3
    Jan 19, 2005
    308
    clayton, ca
    Just make sure the amp has an adjustable or variable high pass x-over in it. I haven't played with orion amps in about ten years, so I can't answer that for you. You should not need more than 30-40 watts rms amp power for those speakers, so make sure they do not over sell ya.
  7. Z3PR
    Z3PR Banned
    Mar 30, 2002
    19,217
    Everywhere
    It's a 4 channel amp and rear speaker are rated at 100 watts rms. I figure I can turn down gain for front speakers. Yes, it has variable high pass x-over. I'm a thrifty bastard, I'll watch ebay for this amp for 6 months or better. If one doesn't come along cheap enough, then I'll buy wholesale.
  8. AudioMaster
    AudioMaster Registered Member
    Jul 26, 2002
    28
    Southern Utah
    For as cheap as they are bass blockers would be fine for now. Save you from blowing the front speakers. An amp with a built in HP filter is the way to go.
