Bass Remote Control
Discussion in 'Audio' started by Muddytazz, Feb 13, 2005.
  1. Muddytazz
    Muddytazz 1 ton status
    Jun 30, 2002
    20,073
    Salem, Or.
    Can a Bass Remote Control be installed with any amp to control the bass from of the subs from the drivers seat?
  2. Muddytazz
    Jun 30, 2002
    20,073
    Salem, Or.
    Found my own answer, the amp has to be remote capable for it to be used.
  3. cochino12
    cochino12 1/2 ton status
    Dec 23, 2003
    563
    Parker, Co
    not 100% true, I have put a control/gain know in line with the rca's before. You can find them at radio shack
  4. Jonny-K5
    Jonny-K5 1/2 ton status
    May 27, 2003
    1,654
    SoCal
    some crossovers/equalizers have built in remote gains. my MTX crossover does.
  5. Spkrman
    Spkrman Registered Member
    Jan 23, 2005
    39
    Matteson, IL
    to answer a Q that may come up...
    bass control knobs are not interchangeable.. for example - you cant take a kicker bass knob and plug it into an MTX amp.
    The wires may not control the same things, and you could fry something.
    to say it won't ever work wouldn't be entirely true... most every bass knob is hooked up with phone cord, and I'd find it hard to believe everyone is doing something different.
  6. Greg72
    Mar 5, 2001
    15,681
    1,392
    642 Days to BB2018
    Yep....these days it's typically a function of the amp, and usually an optional knob/cord to plug into the jack on the amp.
    In the old days one of my favorite equipment companies (a/d/s) put that capability in their equipment, though they did it via the crossover. Once the bass frequencies had already been split off, the knob was then use to control the amount of voltage travelling out on those RCAs.....It made it amplifier independent.
    I suppose there are other companies that did it the same way, so if you wanted that feature bad enough, you could try to locate the a/d/s 642CSi (or 642ix)crossover and AC-501 bass control knob on eBay.... and wire them in????
    This is the setup I have for "The System" that is now in boxes, but will someday be re-installed in the '72. It's the one in my photo gallery.
