Bathroom improvement question... Moisture resistant wood?
Discussion in 'The Lounge' started by newyorkin, Apr 23, 2005.
  1. newyorkin
    newyorkin 1 ton status
    May 8, 2001
    16,555
    157
    Los Estados Unitos
    What's the best wood to use in a bathroom? I've heard Cedar stands up to weather (moisture) pretty well, but we' probably going to have an oak finish vanity, and Im' not sure I want the wood mismatched.
    I'm going to use stained pine for a shelf, but I need to add 2 pieces of trim and that's the wood I'm wondering about.
    1 piece will go at the top of the shower tile surround, the other will go down the edge of the tile where it meets a doorframe (same as a wall), basically the end of the shower surround.
    Thanks for any responses!
  2. Eric M.
    Eric M. 1/2 ton status
    Dec 10, 2001
    2,118
    Oakland, CA
    Use anything you'd like, just seal it well. Put it up, seal it and then run a bead of clear caulk (silicon or acrylic latex - I like the Dap Alex Plus II) along the top and bottom.
    Redwood and Cedar are very water resistant when left unsealed, but, will run and stain when they get wet. Looks "pretty" on a fence or trellis .... looks like you made a mistake if it happens in a bathroom.
    Good Luck,
    Eric M.
  3. Stickseler
    Stickseler 3/4 ton status
    Mar 23, 2001
    6,503
    Northern Virginia
    If I knew somthing about wood i would be glad to help you :grin:
  4. hi pinion
    hi pinion 3/4 ton status
    Sep 25, 2003
    5,354
    **PLUMBING THE WORLD**
    USE GOOD WOOD!!! :grin:
    I dunno, never did the whole wood on water deal :)
  5. Storm Trooper
    Nov 24, 2000
    4,640
    Just use a good finish (maybe a marine spar?), precut your wood and seal it on all sides. Use whatever wood matches the rest. It will look much better.
    Oh, and put in a good fan and use it :)
  6. 3 on the tree
    3 on the tree 1/2 ton status
    Oct 16, 2004
    3,970
    gunnison colorado
    Cypress, if you can get it. I read folks are pulling old submerged Cypress logs outta swamps, milling it and selling for big bucks.
  7. Storm Trooper
    Nov 24, 2000
    4,640
    My whole front deck on my house is made out of cypress. It still needs to be sealed or it turns gray/black but when cleaned and sealed it looks like pine and is a much harder wood. It only comes in std sizes and not in trim.
  8. Stickseler
    Mar 23, 2001
    6,503
    Northern Virginia
    Cypress is a good choice. Oak is not meant to be submersed in water but it does stand up to high moisture. People use alot of white oak in wet conditions especially barns and stuff.
  9. justhorsinaround
    justhorsinaround 3/4 ton status
    Sep 16, 2003
    6,798
    Northerish Phoenix, Az
    The also sell plastic that looks pretty good as well for trim.
