BatmanJR can u help me?
Discussion in '1982-Present GM Diesel' started by Jaguargt, Aug 8, 2003.
  1. Jaguargt
    Jaguargt Registered Member
    Mar 14, 2003
    46
    Guatemala
    I have a leak in the throtle shaft, can i just remove the intake manifold, and change the seal in the shaft? thanx.
  2. Batmanjr
    Batmanjr 1/2 ton status
    Mar 23, 2001
    1,537
    Copperas Cove, Texas
    If I remember correctly, you will have to take the whole pump apart to replace that seal.... That's alot more work than I suggest anyone getting into.... DieselDan or some of the other guys on here might know better or a secret to getting that seal out, but I don't mess with that one... Sorry! In any way, I would take the pump out if you were to break into trying to rebuild it!
  3. BlueBlazer
    BlueBlazer 1/2 ton status
    Feb 15, 2001
    1,940
    You only have to remove the governor IIRC, the flyweights, springs and such. Call a pump shop near you and see what they would charge to replace it if you bring the pump to them. I wouldnt suggest doing it on your own if you dont know the inner workings of the pump.
  4. Jaguargt
    Mar 14, 2003
    46
    Guatemala
    Thanx guys, i think i'll take the pump to the injection lab, thanx.
