Batteries or alternators charging to much?
Discussion in 'The Garage' started by protechk5, Dec 30, 2006.
  1. protechk5
    protechk5 1/2 ton status
    Sep 26, 2004
    2,015
    VA
    On my m1008 with 6.2 thats still 24volts, my volt meter (the one thats on the right hand side where the a/c vent would be) is going all the way to the right, pass the green and now in the orange. And like my head lights and dash lights seem alot brighter than normal, or at least when Im on the gas, when I let up they dim a bit. But it just started all this a few days ago. Is this normal, or is there something wrong with my junk.
  2. 73k5blazer
    Dec 28, 2001
    4,987
    38
    The Rustbelt
    THe voltage regulator, which is contained within the alternator, has probably gone out to lunch. You need to replace the alternator(s) most likely.
  3. rjfguitar
    Aug 28, 2002
    9,096
    144
    california
    Can you hear more altenator whine? That would give a clue that the altenator is putting out a lot of power.
    How about your battery? Does it stink like a bad egg yet?
  4. 3 on the tree
    3 on the tree 1/2 ton status
    Oct 16, 2004
    3,970
    gunnison colorado
    If your lights get brighter when you rev, then the alt is working. I have never seen a volt reg go bad, and still charge. I suspect a bad/weak battery.
  5. protechk5
    Sep 26, 2004
    2,015
    VA
    Well my batteries crank fine, and I havent heard my altenators whine yet. Is it bad that the needle is all the way to the right, in the orange(its not in the picture cuz it wasnt running, but when it is running thats where it stays)
  6. protechk5
    Sep 26, 2004
    2,015
    VA
    is that gauge even factory on a m1008?
  7. rjfguitar
    Aug 28, 2002
    9,096
    144
    california
    Sounds like you are overcharging to me. You'll find out, as the batteries will start to make a sizzling sound and stink with a long continued hard overcharge.
  8. protechk5
    Sep 26, 2004
    2,015
    VA
    haha sweet! anyway prevent this?
  9. JEBSR
    JEBSR 1/2 ton status
    Dec 23, 2004
    1,541
    Clarksville, TN
    I have seen many alternators with a bad voltage regulator that overcharged. That is the only thing capable of an overcharging system on a normal setup. The only other possibility that crosses my mind in your situation is if the 12/24 isolator is bad. Most likely the voltage regulator though. Pull both alts and have the m tested. Easy and free.
  10. rjfguitar
    Aug 28, 2002
    9,096
    144
    california
    Yeah, buy a new altenator, or have yours torn down and a new voltage regulator installed.:doah:
