Battery cable broke = rough idle...Help...
Discussion in 'The Garage' started by socal chevy, Apr 1, 2006.
  1. socal chevy
    socal chevy 1/2 ton status
    Nov 18, 2004
    308
    San Clemente, CA
    I did a little wheeling the other day, and didnt realize that I rattled the battery loose, and it fell and broke off the battery cable adapter. The battery must have been laying on the adapter, and worked, because I drove for about 10 minutes, then BAM...NO POWER!... I pulled over and checked the battery, and the adapter (The thing that pinches the wire, and then screws to the battery) was completely broken off. So, I replaced the adapter with a new one, but now my truck drives very wierd. It vibrates alot from the engine compartment when I give it gas, and everytime I stop I hear a "clicking" noise. Does anyone know what happend?...Seems to me like it should drive the same as when the battery was conected before. But maybe the Dizzy is messed up now?... I dont want to drive it, for fear that I might cause additonal damage. Please help. Thanks!
  2. socal chevy
    Nov 18, 2004
    308
    San Clemente, CA
    to the top
  3. socal chevy
    Nov 18, 2004
    308
    San Clemente, CA
    someone help!
  4. socal chevy
    Nov 18, 2004
    308
    San Clemente, CA
  5. 1985_K5_Silverado
    1985_K5_Silverado 1/2 ton status
    Dec 21, 2005
    984
    Corn Country
    I assume you looked around at anything the battery might have struck, dents, cracks in anything? Maybe it cracked a vacuum hose/fitting or bent your EGR linkage (causing EGR at idle, when there should be none). Did the PCV valve get dinged and thus no longer functions properly?
  6. socal chevy
    Nov 18, 2004
    308
    San Clemente, CA
    I didnt notice anything at all. My vacuum lines are not hooked up correctly, so it cant be that. Where is the EGR linkage? And where is the PCV valve?... Im pretty sure it didnt hit either of those, but I will check. Does anyone have any other ideas of what it could be?
  7. ryoken
    Jun 13, 2003
    29,624
    1,380
    Jersey Shore
    maybe ya bashed that #2 plug wire boot on that corner, might be arcing out or something.. start it at night and look for sparks.. or the plug itself may be cracked..
  8. AZ79K5Project
    AZ79K5Project 1/2 ton status
    Jan 15, 2006
    2,082
    Arizona
    x2
    You need to check EVERYTHING that the battery hit. Any battery acid leakage? Clean it off if not aleady done. Don't risk a fire from damaged wires or corrosion damage.
    The clicking is either a relay that is shorted, unlikley unless its an aftermarket add-on. More than likely, its an plugh wire or plug damaged and the spark not making it to the cylinder.
    You may be having other problems as well with the vacuum advance. The routing is outlined on the sticker under the hood (to the right of the hood latch). Looks confusing until you start.
