Battery cable corrosion
Discussion in 'The Garage' started by GMCJason, Aug 5, 2006.
  1. GMCJason
    GMCJason 1/2 ton status
    Dec 23, 2004
    242
    Longmont, CO
    Hey Guys... Talk to me about corrosion on the battery terminals. I went to move the wife's Chevelle this afternoon and it acts like the battery is dead and needs a jump. It happens as this car sits for weeks at a time without being started. Anyway, I pop the hood and there's a boatload of corrosion on the positive terminal and connector. I cleaned it all up and replaced the positive connector since it was broken and she fired right up. What causes the corrosion? Is the battery going bad? Is it because it sits without being run? Anything I can do to stop it? My trucks can sit for long periods of time without this happening. What gives? Thanks for your help.
  2. dontoe
    May 7, 2004
    9,070
    Hickory, N.C.
    You can buy spray on protection just for preventing that. Or use spray red grease, Vaseline or I sure there are other preventive measures.
  3. barneybasher1010
    barneybasher1010 1/2 ton status
    Sep 25, 2005
    908
    PORTERVILLE CA
    WD-40 Works too:D
  4. Cricket
    Cricket 3/4 ton status
    Nov 29, 2004
    8,224
    Colorado
  5. ryoken
    Jun 13, 2003
    29,622
    1,376
    Jersey Shore
    Haha, this is my life.. Come work on boats for a week or 2... You can't imagine the amount of this stuff I see...
  6. GMCJason
    Dec 23, 2004
    242
    Longmont, CO
    Thanks everybody. Maybe I'll try putting something on the terminals to protect them.
  7. ryoken
    Jun 13, 2003
    29,622
    1,376
    Jersey Shore
    we use terminal spray designed for batteries at work, marine corrosion inhibitor works well too.. but grease or vaseline gets you by in a pinch... siliconed felt terminal washers seem to help quite a bit too...
    quality cable, soldered and shrunkwrap battery lugs are a must too....
  8. ntsqd
    ntsqd 1/2 ton status
    Nov 28, 2002
    3,381
    So. CA
    When you say you put a new terminal on there do you mean one of those clamp-on type "repair" terminals? I hope not.
    Second the heat shrink, but use adhesive lined.
  9. dontoe
    May 7, 2004
    9,070
    Hickory, N.C.
    Yeah, I paid around $8.00 a foot for red and black, big enough to go over 1/0 cable lugs. But, it's some good chit!!! :waytogo:
    Main battery
    Aux battery
  10. GMCJason
    Dec 23, 2004
    242
    Longmont, CO
    Yep, you caught me. :whistle: I used the clamp-on type with the old cable. It worked (for now) but the Chevelle doesn't see much road time so I'm not concerned about it being the most heavy-duty fix. Maybe when the battery goes I'll straighten it all out.
    I suppose I should get it right so it doesn't corrode as it sits.
  11. ntsqd
    Nov 28, 2002
    3,381
    So. CA
    Those clamp-on terminals are the start of more trouble than you can imagine. I put them in the "getcha back" range of acceptable repairs, to be deleted at first opportunity.
    I'd fix it b4 the battery goes away.
  12. Metrodps
    Metrodps Strange but nice guy Premium Member GMOTM Winner Author
    Jan 4, 2006
    9,726
    108
    earth
    So you don't have to look:
    To prevent corrosion of cables on top post batteries use a small bead of silicon sealer at the base of the post and place a felt battery washer over it. Coat the washer with high temperature grease or petroleum jelly (Vaseline), then place cable on the post and tighten. Coat the exposed cable end with the grease. Most folks don't know that just the gases from the battery condensing on metal parts cause most corrosion.
  13. diesel4me
    Jul 24, 2003
    17,547
    937
    Massachussetts
    Gangrene...
    We get lots of corrosion here,being close to salty air,and the fact the weather is often humid or wet here.."snow" will form on your battery posts and cables at an alarming rate,and I often see cars at my friends repair shop with so much of it accumulated,you cant even SEE the battery posts OR the cable ends!..and its a given the bolts are whittled away to nothing,and will snap off,when you try using vise grips to loosen them,as no wrench will ever fit them again..
    I use a healthy dose of Arm and Hammer Baking Soda ,dump it right on the crap and posts,and let it fizz for several minutes--household ammonia also works great...wet it down to a paste helps it work faster(hot water is best)....then after its done neutralizing the acid,blast it off with a garden hose..I "douche" my battery posts and cables about once a month this way,and I haven't had any trouble with the truck not cranking due to corroded cables and posts...:crazy:
