battery charger and battery issues
Discussion in 'The Garage' started by TheBlazerKid, Dec 10, 2002.
  1. TheBlazerKid
    TheBlazerKid 1/2 ton status
    Apr 26, 2000
    259
    Raymond, Washington
    ok for some reason the optima yellow top in my blazer always goes dead. even if it only sets for 5 days or so. but thats not my problem right now. blazer has been sitting for about a month (being painted) and like an idiot I had'nt been starting it every once in awhile so i went to put the charger on it, small NAPA trickle charger, and the guage just pegs for like 2 seconds then goes to zero, pegs, zero. so on and so forth. why is it doing this? is my battery shot? I thought these were good battery's?! /forums/images/graemlins/1zhelp.gif /forums/images/graemlins/1zhelp.gif /forums/images/graemlins/1zhelp.gif
  2. Sandman
    Sandman 3/4 ton status Author
    Apr 15, 2002
    5,653
    Pocatello, ID
    Try unhooking the battery cable and then hooking up the charger. Sounds like there is a current drain in the electrical system somewhere. The 2 amp charger is putting out all it can and not sensing any resistance, is reseting itself. If it charges fine with the battery unhooked from the system, You get the joy of finding the electrical problem. If it still does not, Suspect the battery. Good luck.
