battery charger question...
Discussion in 'The Lounge' started by 84gmcjimmy, Jun 9, 2005.
  1. 84gmcjimmy
    84gmcjimmy 1 ton status
    Dec 3, 2003
    12,838
    B.C. CANADA
    This isn't truck related, so I will post it in here for someone to see....
    I have a battery charger; it has 2 options 15amp and 2 amp for charging. Along with deep cycle and maintenance free or low maintenance battery option.
    My mom has a toyota corrola with the 22r motor, and the battery is dead (hasn't been running for a couple months) so I need to charge it.
    What will give the best charge, the 15 amp, or the 2 amp?
    I have it on the 15 amp right now :confused:
  2. Can Can
    15,552
    136
    Cochrane, Alberta, Canada
    15 amps will shock charge the sucker. Sometimes you need to do this to blast the plates clean if it won't accept a trickle charge. The 2 amp setting is a trickle charge. Someone once told me that using the trickle setting charges the battery more completely, but I dunno?
  3. 84gmcjimmy
    Dec 3, 2003
    12,838
    B.C. CANADA
    It makes sense that the 2 amp would charge it better.
    I charged it for a couple hours on 15 amp and it didn't start. Starter made a clicking, and dash and interior light came on.
    I have it on 2 amp, and I will try it after breakfast tomrrow.
    Thanks Paul.
  4. 3 on the tree
    3 on the tree 1/2 ton status
    Oct 16, 2004
    3,970
    gunnison colorado
    Does your charger hae an automatic setting on it? This means that as the battery charges up, the charger will lessen the maps going to it. I use 15 amp auto on my charger, the 2 amp is more like a maintenance charge for vehicles that don't get driven that much.What is the amp hour rating on the battery-divide that by 2(amps) and that is how long it will have to charge, if it is completely dead.
  5. 84gmcjimmy
    Dec 3, 2003
    12,838
    B.C. CANADA
    Alright thanks Mike.
    Yeah it has 2 automatic settings and 1 manual. The 2 automatic settings are the 15 amp or 2 amp.
    Thanks.
  6. 89GMCSuburban
    89GMCSuburban 1/2 ton status
    Nov 15, 2001
    3,005
    Thornton, CO
    slower charge hold longer, use the 2 amp for a day or so
  7. kyser_soze
    kyser_soze 1/2 ton status
    Sep 4, 2004
    3,180
    KC Missouri
    use the 2 amp charge and clean the terminals.
