Battery Cutoff Switch
Discussion in 'The Garage' started by caleb22, Oct 31, 2005.
  1. caleb22
    caleb22 1/2 ton status
    Apr 15, 2005
    193
    SC
    I don't drive my Blazer nowadays as much as I like. I wanted to make sure I don't drain the battery while it sits and have a surprise one day when I actually need to drive it.
    Has anyone installed a battery cutoff switch and if so, what kind?
  2. alf4444
    alf4444 1/2 ton status
    Nov 1, 2002
    2,051
    T-ville, ut.
    yup I bought one that clamps on the battery terminal then the battery cable clamps on to it. It was like $5 just spin a knob between on and off :D
  3. RootBreaker
    Nov 29, 2001
    5,118
    173
    Williamstown, NJ USA
    how bout you elaborate on that.... what brand.. how many amps....
    I was gonna do the same thread.. but wondering what all yall winchers are using... as i am going to need something good to 500 amps... :haha:
  4. diesel4me
    Jul 24, 2003
    17,577
    945
    Massachussetts
    New one..
    They have a newer version of the "knob" style switch,that has a small wire and a fuse,so your radio and computer wont lose their memory while its in the "off" position..only thing that sucks,is if you forget to tighten the knob first before starting,you pop the fuse! :doah: ..
    I'm not sure how many amps those terminals are rated for,but I bet they wont take 500 amps for any length of time..Being cheap,I just take one battery cable off myself,if I'm worried about something draining my battery.. :crazy:
  5. BudTX
    BudTX Registered Member
    Oct 4, 2005
    36
    Kansas
    I have one mounted on the floorboard of the 83 K20 that I picked up last month from a local fire department. It is a nice bit of insurance against the battery running down when the truck is parked for a while, and also serves as a quasi-theft deterrent.
    On the downside, I have no idea how it was installed. :dunno:
  6. guido666
    guido666 1/2 ton status
    Feb 16, 2005
    788
    Longmont, CO
    If you like elaborate (read that as "expensive") Flaming River makes an awesome one that is tough, and has a long extension handle you can mount in the cab and disconnect/reconnect the battery at will. I think it's like $125, but I've always wanted to get one.
  7. MarcS
    MarcS 1/2 ton status
    Oct 4, 2002
    515
    NJ
    Check in some boating catalogs, they have some nice switches. Summit and Jegs also have cut-off switches.
  8. caleb22
    Apr 15, 2005
    193
    SC
    I just found a Hella cut-off marine switch on eBay for $8. It's the Hella model 87181, rated for 1000amps/12v. Maybe I'll give that a try. If I have to open the hood to use it so be it. It has a key that removes also.
  9. RootBreaker
    Nov 29, 2001
    5,118
    173
    just post the item number so i dont bid against ya... i want one but will find one that yall aint biddin on.... dont need to fight fellow members :bow:
  10. RootBreaker
    Nov 29, 2001
    5,118
    173
    found this...
    wont work for me - $18
    http://store.summitracing.com/default.asp?target=/egnsearch.asp&N=400152
    Brand: Hella
    Product Line: Hella Battery Master Disconnect Switches
    Switch Actuation: Rotary (turn)
    Continuous Amp Rating: 150 amps
    Surge Amp Rating: 1,000 amps
    Includes Alternator Disconnect: No
    Includes Magneto Disconnect: No
    Waterproof: Yes
    Mounting Bracket Included: No
    Emergency Off Decal Included: No
    Quantity: Sold individually.
    Battery Disconnect Switch, Rotary, 150 Continuous Amps Rating, Each
    Switches for standard and heavy-duty loads.
    Hella battery master disconnect switches allow interruption of the main battery cable for effective protection. The positive or negative cables can be switched off as required. The keys can be removed while in the off position and the current is interrupted. Keep your things protected when your not around.
  11. caleb22
    Apr 15, 2005
    193
    SC
  12. BozoWise
    BozoWise 1/2 ton status
    Mar 28, 2002
    1,224
    Lubbock, TX
  13. az-k5
    az-k5 1/2 ton status
    Oct 15, 2003
    2,774
    Phoenix AZ
    I am using a marine battery switch that doubles a my dual battery manual isolator. Got it locally and it only cost about $40
    It is good for 300 continous amps and I think 700 short amps and around 1000 peak amps.
    (Glows in the dark too)
  14. RootBreaker
    Nov 29, 2001
    5,118
    173
    more info... like who makes it and part number....
    thanks
    Jeff
  15. bigjbear
    Feb 18, 2000
    13,973
    453
    Marietta GA
    Well, from pic I would say its a Blue Sea Systems, model 9001E, made in Bellingham, WA, USA. ;)
  16. az-k5
    Oct 15, 2003
    2,774
    Phoenix AZ
    Go to westmarine.com It is like auto zone but half of the stuff it waterproof and the other half glows in the dark.
  17. grimjaw
    grimjaw 1/2 ton status
    Jun 19, 2004
    944
    Seymour, TN
    I think this is it.
    Manufacturer Style
    BLUE SEA SYSTEMS - 009_272_004_501
    Description
    Rated 350A continuous / 600A Intermittent (5 min) / 700A Cranking (9.75 sec) / 1600A (0.25 sec) Inrush with the new Engine Starting Standard.
    32 Volts DC Maximum.
    Accepts up to 4/0 battery cables.
    Tin-plated copper terminals are 3/8" for better conductivity
    Luminous face plate, pointer and tactile indicators for safe operation in low light
    Case material: Lexan® Polycarbonate
    Luminous label for low light reading.
    Surface mount with four 1/4" fasteners on 3" centers
    Alternator field disconnect switch on 9002e and 9004e models.
    Make-before-break contact design on 9001e and 9002e models.
    Flush mount in a 3 5/8" hole
    4" x 4" x 2 3/4
    Meets all ABYC requirements for battery switches.
    CE and UL listed.
    300A Compact Battery Switch - Off/1/Both/2 3831393 9001E Only $34.99 USD
  18. ntsqd
    ntsqd 1/2 ton status
    Nov 28, 2002
    3,381
    So. CA
    That's the one on my Sub too.
    I have one of the Hella's with the removable key for the Dune Buggy. Doesn't look like it will get installed. Perhaps on it's Baja replacement. Have a second for the Project: Rusty. That key will BE the IGN key - goal for it is simplified wiring.
  19. Boondocks
    Boondocks 1/2 ton status
    May 10, 2005
    129
    Massachusetts
    I installed a battery maintainer in my K5.
    Picked it up from NAPA for about $30. Cost more than the switches, but it keeps the battery fully charged and ready to go. I have yet to suffer a dead or frozen battery since I started using it.
    Of course that means you have to plug it in.
    Couldn't find the NAPA number, but here is a similar unit from J.C. Whitney for $20
