Battery disconnect
Discussion in '1982-Present GM Diesel' started by OFFRDK5, Dec 30, 2003.
  1. OFFRDK5
    Oct 2, 2000
    1,881
    Central IL
    Anyone ever done a quick battery disconnect with a switch and dual batteries? I have an idea, just think there might be something better out there!!
  2. imiceman44
    imiceman44 1 ton status
    Aug 5, 2002
    15,160
    Sacramento, CA
    I used to have one but with my diesel, I need so much power that the switch I was using wasn't up to the task.
    Now I am looking for a bigger one.
    I do however have the warn disconnect plugs for the winch that I was thinking of using.
  3. OFFRDK5
    Oct 2, 2000
    1,881
    Central IL
    Well, thanks for answering. I thought no one had ever done this before!!
    I found a 50 amp one at Farm n Fleet and I really don't think it will hold up considering that I know a starter will melt cables and melt batteries!!!! They say that there is a 300 amp one, but the salesman and I couldn't find it!!
    Think the 300 would hold up? How did you have yours connected? I was thinking about taking both engine grounds and attaching them to the one post then taking that to the engine ground. But I still think that would be way too much power going through there!!
  4. imiceman44
    Aug 5, 2002
    15,160
    Sacramento, CA
    50 amps is no where near enough.
    I have a couple of 170 amp disconnects, and together they should be enough.
    The 300 amp if you can get it would be good, but I am sure it's gonna be mucho $$$$$.
    I was trying to get one that big but it was more than $500.
    As for how:
    Well you want to disconnect the positive end, the one going to the starter.
    If you want more details, email me. /forums/images/graemlins/thumb.gif
  5. OFFRDK5
    Oct 2, 2000
    1,881
    Central IL
    Well, the disconnect I got was a 50 amp continuous and a 300 amp max. I still think I would have turned it into a pile of scrap in a few seconds!!
  6. imiceman44
    Aug 5, 2002
    15,160
    Sacramento, CA
    You want something that can take at least 150 amp continuous.
    Last night I found one at Harbor freight that was I think 300 amp continuous and 700 peak.
    I might be trying this one.
    It's the simple Jack knife style and it's $20
