Battery issues
Discussion in 'The Garage' started by jms, Jun 16, 2005.
  1. jms
    jms 1/2 ton status Author
    Jan 24, 2001
    1,683
    Ended up w/ yellow main, red aux.
  2. bugspray
    bugspray 1/2 ton status
    Jan 13, 2004
    110
    Phx, Az
    Before buying new ones, try dropping them from waist height. I heard the plates will "freeze" together, and dropping them will break em free to take a charge.
  3. mrk5
    Apr 20, 2004
    12,329
    1,037
    Northern Colorado
    I've heard that several times before too.
  4. mrk5
    Apr 20, 2004
    12,329
    1,037
    Northern Colorado
    I'm only running one red top right now. I plan to get a yellow top if I ever get an electric winch. So I would say one red and one yellow. Some where I've gotten the impressoin that the deep cycle battery will work better with a winch.
  5. mrk5
    Apr 20, 2004
    12,329
    1,037
    Northern Colorado
    Summit has always treated me very well.
    Maybe someone in the evening crew can give you some more opinions. :dunno:
  6. spearchucker
    spearchucker 1/2 ton status
    Nov 17, 2003
    1,556
    Bay area, CA
    It seems odd that both batteries die at the exact same time. Are you sure your alternator is working correctly or you don't have a short somewhere?
  7. greg mgm
    greg mgm 1/2 ton status
    Apr 6, 2005
    152
    Pine Cove (near Idyllwild) CA
    Im a noob to the site, but far from it with trucks.. What worked for me was to pull the positive cable from the battery and hook up a ohm meter from ground to the open cable. Turn off everything, and close the doors, and the reading should show high resistance. (I use a non-digital meter) If there's a low resistance, start pulling fuses one at a time to see what circuit has the draw. My truck battery died also, and turned out to be that the radio drew too much from the battery (it was from the radio memory, even though it was off), but in my case the truck sat for a couple of months.
  8. spearchucker
    Nov 17, 2003
    1,556
    Bay area, CA
    Fixed it for you, you had it backwards. Minimal resistance would be close to a short == bad.
    A better way to do the same sort of test is to check the current draw while the battery is hooked up.
  9. greg mgm
    Apr 6, 2005
    152
    Doh!! OK you got me!!! I corrected my post. Thanks for simplifying the test also.
  10. seschev3
    seschev3 1/2 ton status
    Jan 19, 2005
    308
    clayton, ca
    Stay with optima and get a yellow top. I run 3 yellow tops in my rig and never have power problems. I also use a 3 way isolator to seperate all 3 of them. If any of them die, I can jump off the others at the isolator. I have used optimas in my rigs for at least 13 years and love them.
  11. MOABDADC22
    MOABDADC22 1/2 ton status
    Jul 24, 2001
    1,348
    Cheyenne, Wy
    I am sold on Optima's. I will never, ever buy any other battery brand again. I run dual red tops in my Blazer and I love them. Dropping them from 3-4 feet will bring them back to life most of the time.
  12. Roz
    Roz 1/2 ton status
    Mar 27, 2005
    900
    San Diego
    if u are sightly familiar with dc then i wouldnt worry about the new batts, just make shure u use a multimeter to check ure resitance in line. i have had an isolater stick(?) before (after i rolled about 30' into a creek)so it wasnt very effective isolator (that confused me-i thought they were solid-state?), so possibly test leads to make shure u have isolation. i agrree with optimas
  13. mudhog
    Nov 6, 2000
    17,899
    portland oregon
    if you have a winch or plan on getting one get the yellow top as the second bat :D :D
  14. Boondocks
    Boondocks 1/2 ton status
    May 10, 2005
    129
    Massachusetts
    I have had an Optima fail as well, but they have an 3 year free replacement warranty. My local battery shop replaced it on the spot, no questions asked, and I didn't have a receipt.
  15. Blue85
    Blue85 Troll Premium Member
    Jul 26, 2000
    9,072
    483
    Grand Rapids area
    When a battery is really dead, you don't want a trickle charger. You want to hit them with a lot of current. If you don't have a big charger, jump it from a running vehicle.
  16. Storm Trooper
    Nov 24, 2000
    4,640
    Sorry to hear about the problem. I have two yellow tops and they seem to work good. I also use the PM 140A alternator. Maybe Blue is right and you should try it. Isolators can go bad as easy as anything else so make sure you recheck it after you get some good batteries in there so you don't have an unexpected relaps of the dual dead batteries again. I dumped my isolator and just doubled them up. Hope you get it figured out bud.
  17. mrk5
    Apr 20, 2004
    12,329
    1,037
    Northern Colorado
    I'd also search over at Pirate. You can find a lot of good info on stuff like this that is not vehicle specific.
