Battery overflowing
Discussion in 'The Garage' started by mountainexplorer, May 4, 2006.
  1. mountainexplorer
    mountainexplorer 1/2 ton status
    Nov 14, 2001
    4,903
    Spokane, Wa./Ione, Wa
    It's not a good thing to see water overflowing from a new battery when a motor is running. Is that usually the regulator built into the alternator going bad and overcharging it?
  2. 1979jimmy350
    1979jimmy350 1/2 ton status
    Mar 24, 2004
    3,069
    Ann Arbor Mi
    it could be the regulator or there is a short to ground causing the battery to heat up, but if the battery still holds a charge when the truck is off i would suspect the alternator
  3. mountainexplorer
    Nov 14, 2001
    4,903
    Well, the only ground I have is from the alternator bracket. Right now I just have the battery hooked up to cables but sitting on the front axle/knuckle since theres no front nose clip. Maybe it's a lack of ground to the body? Or could that do it?
  4. 1979jimmy350
    Mar 24, 2004
    3,069
    Ann Arbor Mi
    no i have run my truck the same way, and had my battery start to boil and over flow when the wire to the alt fell and touched the frame. The battery in a way acts like a resistor the more current that is put through it the hotter it gets and the only two ways to cause a large amount of current to flow is a major short to ground or to much current going in from a bad regulator
  5. mountainexplorer
    Nov 14, 2001
    4,903
    Must be a bad regulator. Doesn't spark at all when I touch terminals, and the wire isn't grounding out anywhere.
  6. Greg72
    Mar 5, 2001
    15,680
    1,391
    642 Days to BB2018
    Throw a meter across the terminals when off, and then again with the engine running.... conventional wisdom says anything over about +15V is not going to end well.
    :usaflag:
