Battery Question
Discussion in '1982-Present GM Diesel' started by schlechto, Mar 12, 2003.
  1. schlechto
    schlechto Registered Member
    Aug 4, 2001
    56
    Carnation, WA
    What do you guys think about running 2 optima yellow 900cca batteries?
  2. bigblock454
    bigblock454 Clack Clack Clack Premium Member
    Jun 18, 2002
    546
    16
    Terre Haute IN
    That would work fine. Optima batteries are excellent wet cell replacements.
  3. arveetek
    arveetek 1/2 ton status
    Mar 1, 2002
    722
    Granby, MIssouri, USA
    Aren't the yellow tops the deep cycles? If so, the red tops would be a better application for the demands of starting the diesel engine.
    Casey
  4. bigblock454
    Jun 18, 2002
    546
    16
    Terre Haute IN
    As long as the CCA rating is high enough a Deep Cycle is even better. At 900 CCA they should be more than enough.
  5. 4x4dreamer
    4x4dreamer 1/2 ton status
    Jul 8, 2002
    874
    St. Petersburg, FL
    I thought deep cycles don't like constant charging. I'd always heard not to use them in automobiles.
  6. imiceman44
    imiceman44 1 ton status
    Aug 5, 2002
    15,160
    Sacramento, CA
    It's not that they don't like constant charging, they can't usually give to much current at once, but now OPTIMA is changing that with their deep cycle high cranking battery.
    I'd say if it really is the 900CCA, 900CA then yes go with them.
  7. schlechto
    Aug 4, 2001
    56
    Carnation, WA
    Thanks for the guidance guys. I was thinking about using them because they can retain the charge longer and have better amperage than the red tops.
