Battery Question
Discussion in 'The Garage' started by HD, Sep 9, 2003.
  1. HD
    HD 1/2 ton status
    May 22, 2003
    132
    Ridgecrest, CA
    Okay I got the cheepest battery I could find and now that I finily have my K5 running the starter is starting really slow and sometimes stops and the goes again. So the question is what number of cranking amps should I be looking for?
  2. mudhog
    Nov 6, 2000
    17,899
    portland oregon
    sounds more like timing /forums/images/graemlins/eek.gif
  3. Can Can
    15,555
    149
    Cochrane, Alberta, Canada
    I personally wouldn't run anyhting smaller than 850 CCAs(I have a 1000 CCAs right now), but I live in a little colder climate than you /forums/images/graemlins/wink.gif. In the middle of winter up here a less powerful battery just doesn't cut it.
  4. 83ZZ502_Jimmy
    83ZZ502_Jimmy 1/2 ton status
    Feb 7, 2001
    3,103
    Richmond, VA
    I'd also check all your connections for corrison and tightness. A bad/dirty connection can cause these problems.
    John
  5. HD
    HD 1/2 ton status
    May 22, 2003
    132
    Ridgecrest, CA
    I think I will go with the 1000 because I do plan to move back to WV someday and get out of the desert /forums/images/graemlins/laugh.gif
  6. steelsoldiers
    steelsoldiers 1/2 ton status
    Oct 17, 2002
    365
    Charleston, West Virginia
    I run 2 880 CCA Optima redtops in series here in West Virginia and it works just fine. Come on back from CA, we could use a few more K5s and hillbillies around here. /forums/images/graemlins/thumb.gif
  7. gravdigr
    gravdigr 1/2 ton status
    Apr 15, 2003
    1,129
    Tyrone, PA
    You understand running a pair of 12v batteries in series will give you 24v? Run those same batteries in parallel and you will get the same 12v but double the single batteries amperage. I doubt you are running in series as unless you converted your whole vehicle to 24v you would blow out every electrical component and light in the vehicle.
  8. Can Can
    15,555
    149
    Unless I'm mistaken, I'm pretty sure that all M1008s and M1009s came from the factory with 24 volt systems.
  9. gravdigr
    Apr 15, 2003
    1,129
    Tyrone, PA
    Ahh they must have changed from the older models then. My shop manual for '79 lists the diesel as a 12v system with 2 bats in parallel.
  10. HD
    HD 1/2 ton status
    May 22, 2003
    132
    Ridgecrest, CA
    How would that effect the starting?
    I did get a new battery, I got one with 1000 cranking amps (800 CCA), but it still does the same thing. Any help please /forums/images/graemlins/confused.gif
  11. Can Can
    15,555
    149
    If your timing is too far advanced, it's hard for the motor to turn over. Can you describe in detail what exactly the motor does and sounds like when you turn it over?
    Have you checked your starter? Maybe it's on the way out.
  12. mudhog
    Nov 6, 2000
    17,899
    portland oregon
    if it is just slightly advanced it will be hard to start like that when warm if its more advanced it will be hard to start all the time try backing the timing off a bit and see what it does then /forums/images/graemlins/thumb.gif
  13. HD
    HD 1/2 ton status
    May 22, 2003
    132
    Ridgecrest, CA
    Okay checked the timing and it was way off. So I pulled it back and now I don't have the tuff start anymore. Thank you for all of your help /forums/images/graemlins/thumb.gif
