Battery tray Question?
Discussion in '1969-1972 K5 Blazer | Truck | Suburban' started by kenaik5, Feb 3, 2006.
  1. kenaik5
    kenaik5 Registered Member
    Oct 25, 2005
    19
    oregon
    I have got to replace my battery tray in my 72 K5, and i have noticed that it matters whether or not you have A/C? Why is this? I currently do not have A/C, but i will be installing Vintage air this summer. One more thing is i have got to modify the new tray in order to accommodate a new billet battery hold down that i have just purchased. I does not fit in between the sides of the stock hold down so I'm going to be cutting one side off in order to fit it.My question is should i buy one for a vehicle with A/C if I'm going to install the vintage air this summer? Thanks
  2. BobK
    BobK 1/2 ton status
    Oct 5, 2000
    1,604
    Petrolia,Ontario,Canada but working in Port Huron,
    A/C trarys have a holdown for 2 aluminium A/C lines,non-A/C tray does not have this holddown.
    here is a pic from LMC's catologe.(click image to enlarge)
  3. tom4
    tom4 Registered Member
    Aug 8, 2005
    86
    dallas
    This might not help. I didnt have ac on my 72 but I just took 2nd gen battery tray and with a little fabrication got it to fit in mine. I don't know about the A/C though.
  4. Scrubby
    Scrubby 1/2 ton status
    Dec 1, 2001
    114
    Boise, ID
    I think you will be ok with the non A/C one. The vintage air probably will have the lines running in different places anyway. Even with the stock A/C, I'm not sure this extra bracket is really needed.
  5. garlicbreath
    garlicbreath 1/2 ton status
    May 17, 2003
    1,136
    Denver
    If your going to install a Vintage air system, have you asked them about the battery tray?
  6. 72chevydsl
    72chevydsl Registered Member
    Jan 22, 2006
    12
    modesto CA
    I just put a vintage air system in my truck a few weeks ago, the kit comes with a bracket that bolts to the battery tray. I didnt have an ac battery tray so I just modified their bracket and bolted it to the inner fender. So I guess the choice is yours. Just make sure you support the hard lines some way or they could crack over time from vibration.
