Battery Voltage
Discussion in 'The Garage' started by MontanaLifted, Dec 5, 2003.
  1. MontanaLifted
    MontanaLifted 1/2 ton status
    Aug 27, 2002
    171
    What is the Voltage gauge supposed to read if everything is good???
  2. Muddytazz
    Muddytazz 1 ton status
    Jun 30, 2002
    20,073
    Salem, Or.
    IIRC around 14volts
  3. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    12 volts with the engine off. 13.8 volts with the engine running. /forums/images/graemlins/cool.gif
  4. MontanaLifted
    Aug 27, 2002
    171
    I have a 77 chevy pickup
    I assume IIRC is the computer for a new rig?
  5. heavy4x4
    heavy4x4 1/2 ton status
    Aug 28, 2002
    3,270
    Delafield, Wisconsin
    IIRC
    "If I Recall Correctly"
  6. dyeager535
    26,979
    Don't trust the voltage gauge unless you've put a voltmeter on the alternator/battery.
    Check that you ARE seeing the 13+ volts when it's running at both of those places, and then just make sure your gauge reads in the same place all the time. If it drops or increases from its "normal" position, you've got problems.
    Most of the stock ones I've seen run just over the halfway mark, but with the age most of these are, it can vary.
  7. gravdigr
    gravdigr 1/2 ton status
    Apr 15, 2003
    1,129
    Tyrone, PA
    anywhere between 13 and 15 volts is acceptable. Lower and you are draining the batterey. Higher and you are cooking it.
  8. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    12.6-12.8 volts with the engine off. 13+ volts with the engine running. /forums/images/graemlins/cool.gif
    Fixed it for you. /forums/images/graemlins/thumb.gif 12.0 volts is a completely dead battery.
  9. Muddytazz
    Jun 30, 2002
    20,073
    Salem, Or.
    Wrong again /forums/images/graemlins/rolleyes.gif
  10. dyeager535
    26,979
    Yeah, gotta say, the battery may not be in great shape at 12 volts or less, but I've driven home before with a dead alternator, turned out to be 10 volts (at the battery) by the time I got back.
    Lights were a little dim, but no noticeable difference in the way she ran.
  11. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Actually, no. 12.0 volts is considered a 0% state of charge. You can kill a battery further (I see that every day) but at 12.0, a starting battery is considered completely dead.
  12. Muddytazz
    Jun 30, 2002
    20,073
    Salem, Or.
    I've had batteries last me yrs with 12.0 volts when the ign is in the off position
