Battery welding...what did I do wrong?
Discussion in 'The Garage' started by bnate, Jan 29, 2007.
  1. bnate
    bnate 1/2 ton status
    Mar 6, 2004
    138
    San Jose, CA
    Looking to do some tack welding on a cheapy Bestop box, so that I can take it to someone to weld up properly. It's 16 guage steel. I linked up the batteries like this article....
    http://www.safari4x4.com.au/80scool/tech/batweld/batweld.html
    and the middle battery positive post just about cooked off when I first began to do the first weld.
    what did I do wrong? :confused:
    any advice?
  2. mikey_d05
    mikey_d05 1 ton status GMOTM Winner
    Nov 23, 2004
    10,453
    Minnesota
    As long as you wired all the batteries in series there shouldn't be any problem. :confused:
    Bad battery?
  3. merace19
    merace19 1/2 ton status
    Sep 19, 2003
    372
    Mobile, Alabama
    You either did not have it tight or you have it backwards. If the cables were loose it will melt it also. It will ark trying to bridge the gaps around the post. I did the same thing years ago and it melted the cable between the batteries. Oh yeah it fried the battery too so lucky i had just bought it from Walmart. guess what i did...................
  4. bnate
    Mar 6, 2004
    138
    San Jose, CA
    Come to think of it, it was loose. THAT'S WHAT HAPPENED....What I dope I am....should have known.
    Another quick question, are all top posts screw off/threaded to replace??
    I see from the autoparts store that they have threaded top posts. I guess at this point the battery can't get much worse if I try to remove the post....
  5. bnate
    Mar 6, 2004
    138
    San Jose, CA
    Forgot to say THANKS ! !
